MARS for ASA Active/Active w/IPS
Feb 28th, 2007
Hello -
I'm curious as the correct way to add an active/active ASA cluster both with IPS modules to the Mars monitoring list. We have 2 contexts on the ASA, so should I specify the ASA device and two security contexts or just the ASA and 1 additional security context? I'm also wondering if I should split the monitoring and make it look as if there are two firewalls within MARS since there are two seperate IPS devices. The documentation really doesn't get into this too much.
Thanks in advance.
