BLF and Speed Dial on CCM5
Answered Question
Feb 28th, 2007
I'm searching the way to configure BLF and Speed Dial from the ccmuser with the CCMV5. Is it possible ? If yes, how can I do ?
Thanks for your help
Correct Answer by rob.huffman about 9 years 7 months ago
Hi Gadacha,
BLF/Speeddials can only be configured by the Admin :(
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
khchiang Wed, 02/28/2007 - 18:21
Dear all,
under 5.0 (2000.1) was supported less 14 BLF on 7914, upgrade to 5.04(2130)which will solve it.
enable presence to allow (default restrict)
& change CCS to allow all.
gadacha-fouad Thu, 03/01/2007 - 02:55
Thanks, but the question is:
Is it opssible for a user to configure their own speed dials and BLF from the ccmuser (not the ccmadmin) ?
Correct Answer
rob.huffman Thu, 03/01/2007 - 05:39
Hi Gadacha,
Hope this helps!
Rob
