Configuring PATing on more than one router interface
Feb 28th, 2007
Can I configure PATing using the keyword "overload" on more than one router interface; when trying to configure more than one NAT rule using the keyword "overload" it gives an error that dynamics NATing is already in use.
Haitham
Overall Rating: 4 (1 ratings)
dradhika Wed, 02/28/2007 - 23:13
Hi Haitham,
Yes you can use it on more than one interface.
'dynamics NATing is already in use' is unsually given when you are trying to change a rule from which the ip address is already in use.
Were you trying to give a different interface for the same access list?
Normally for one access-list you can use only a single interface.
Let me know if you were trying something different.
Radhika
haithamnofal Wed, 02/28/2007 - 23:45
Hi Radhika,
What I meant will be clearer when I give this senario and then let me know if what you mentioned in your post is applicable here or not:
interface FastEthernet0/0
ip address *.*.*.*
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address *.*.*.*
ip nat outside
duplex auto
speed auto
interface FastEthernet0/2
ip address *.*.*.*
ip nat inside
duplex auto
speed auto
access-list 1 permit any
ip nat inside source list 1 interface FastEthernet0/0 overload
Now, when I try to enter the command:
ip nat inside source list 1 interface FastEthernet0/1 overload
I receive an error reading that dynamic NAT is already in use. I need to have dynamic NAT enabled on both fa0/0 and 0/1 because I am load balancing between the 2 link. Can you please clarify your point in your previous post based on my scenario?
Haitham
dradhika Thu, 03/01/2007 - 06:04
Hi Haitham,
I can think of the following solution.
Try creating two extended access-lists,
Access-list one includes networks from f0/2 to f0/0 and access-list two includes networks from f0/2 to f0/1
now you can create two dynamic rules,
ip nat inside source list one interface f0/0 overload
ip nat inside source list two interface f0/1 overload
Now when the traffic goes through f0/0 its ip address will be used and when the traffic goes from f0/1 its ip address will be used.
Hope this helps,
Radhika
