Inverse mask & access-list question
Answered Question
Feb 28th, 2007
Given the access-lists:
"access-list 120 deny tcp 207.16.12.0 0.0.3.255 any eq http
access-list 120 permit ip any any"
Then this is the traffic:
a)source ip 207.16.13.14, destination=http
b) source ip 207.16.32.14, destination=http
Question:
Are the traffic above on a) and b) denied or permitted?
I am kind of confused on how to visualize this. I tried to write source IP in binary format:
207.16.32.14=
3rd and 4th octect only->
.32.14 = 00100000.00001110
mask=03.255= 00000011.11111111
But honestly I can't visualize how to determine whether the inverse mask 0.0.3.255 would deny or permit this. Can you help me understand how I should approach this problem?
Correct Answer by CSCO10892433 about 9 years 7 months ago
Reread your posting, looks like I misunderstand your question.Here is the correction:
207.16.12.0 written in binary format is (only 3rd and 4th octes are ahown)
00001100 00000000
and the mask is
00000011 11111111
the topmost 6 bits should match exactly, so address with the following pattern
000011xx xxxxxxxx (where x= 0 or 1)
will match the source address field of ACL
The address range that match the ACL is
00001100 00000000 to 00001111 11111111
witten in digtal format, it is
12.0 to 15.255
So, the answer is A.
SSLIN
Overall Rating: 5 (1 ratings)
ggilbert Wed, 02/28/2007 - 16:09
With the ACL 120 the network or the addresses which will be allowed are
207.16.12.0 - 207.16.15.255
So, option (a) traffic will be permitted.
Option (b) traffic will be denied.
Hope this helps
Cheers
Gilbert
Rate this post, if it helps.
ggilbert Wed, 02/28/2007 - 16:14
207.16.12.x Is the network
0.0.3.255 is the subnet mask (wildcard mask)
so
255.255.252.0 will be the real subnet mask.
Wild card of "0" means "255" with the normal mask
So, wild card of 3 means 255-3 which is equal to 252.
wild card of "255" means 0 in the subnet mask format.
So, wildcard mask - 0.0.15.255 means 255.255.240.0 in subnet mask.
Does this help!!
Gilbert
CSCO10892433 Thu, 03/01/2007 - 00:32
Hi news2010a
First, there is an inconsistency in your question. Is it 207.16.12.0 or 207.16.32.0? I suppose it's 207.16.32.0 and try to give you an explanation.
For the inverse mask ussed in ACL,bit "0" means match exactly, bit "1" means don't care. In this case, the topmost 6 bits of the third octect (and all bits in 1st and 2nd octes) should match exactly and the rest of the bits need no care.
So, any address with this pattern: 001000xx xxxxxxxx (where x = 0 or 1)will match the source address field of the ACL. Writing these addresses in binary format, they should be:
00100000 00000000 to 00100011 11111111
or in digtal format:
32.0 ~ 35.255
To your question, any address ranging from 207.16.32.0 to 207.16.35.255 will match the source address field in the ACL.
SSLIN
Correct Answer
CSCO10892433 Thu, 03/01/2007 - 00:52
00001100 00000000
and the mask is
00000011 11111111
12.0 to 15.255
SSLIN
news2010a Thu, 03/01/2007 - 09:52
I think finally I understand how to do this sucker! You guys are rulers.
