T.38 Problem
Feb 28th, 2007
Hello, I have problem with FAX Server I can Sending Faxes but I do not can Receive FAX.
It appears to be FAX server Not negociate T.38
0x3956 11B9 0x46AF26EC 0/0/1:1.1 0/1:2 1130 g711ulaw 9000/1004
R-2811-C#sh voice call sum
PORT CODEC VAD VTSP STATE VPM STATE
0/0/1:1.1 g711ulaw n S_CONNECT R2_Q421_IC_ANSWER
dial-peer voice 9000 pots
destination-pattern 9[1-9]......
direct-inward-dial
port 0/0/1:1
forward-digits 7
no register e164
dial-peer voice 1004 voip
destination-pattern 1130
session target ipv4:192.168.70.5 /*--FAXSERVER */
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco no vad
Can anyone help.
Thanks.
