urgent! can't connect to FWSM
Feb 28th, 2007
Hi all,
I have Catalyst 6513 + FWSM. Normally, I use the command "session slot 1 process 1" to connect to FWSM, and I only type password "cisco". Now, I create one usename "cisco" and then, I no username cisco. Now, I connect to FWSM and it asks me "username", I don't kown the default username of FWSM, if you know , please help me.
ROBERTO TACCON Wed, 02/28/2007 - 22:01
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/mod_icn/fwsm/fwsm_3_1/fwsm_cfg/mgacc_f.htm#wp1042046
Recovering from a Lockout
In some circumstances, when you turn on command authorization or CLI authentication, you can be locked out of the FWSM CLI. You can usually recover access by restarting the FWSM. However, if you already saved your configuration, you might be locked out.
The default passwd:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/mod_icn/fwsm/fwsm_3_1/fwsm_cfg/start_f.htm#wp1054192
* Step 2 Log in to the FWSM by entering the login password at the following prompt:
hostname passwd:
By default, the password is cisco.
* Step 4 Enter the enable password at the prompt.
By default, the password is blank,
