ISDN Dialer Config ??????
Feb 28th, 2007
I have following ISDN Dialer Backup config (plz chk below) my serearl Links is down between my two router ABC and XYZ. kindly chk the config and tell is theresome thing worng becoz i could not Connect my tow differnt network on the ISDN plz chk and suggest.
waiting for ur ans.
Router ABC
nterface Serial1
bandwidth 2048
backup delay 1 1
backup interface Dialer1
ip address 192.168.240.1 255.255.255.252
no ip directed-broadcast
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
ppp authentication chap
interface Dialer1
ip address 192.168.10.1 255.255.255.252
encapsulation ppp
dialer remote-name XYZ
dialer idle-timeout 300
dialer string 0212740020
dialer pool 1
dialer-group 1
dialer-list 1 protocol ip permit
ip route 192.168.223.16 255.255.255.240 Dialer1
Router XYZ
interface Serial0
bandwidth 2048
ip address 192.168.240.2 255.255.255.252
no ip route-cache
no ip mroute-cache
backup delay 1 1
backup interface Dialer0
interface BRI0
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
interface Dialer0
ip address 192.168.10.2 255.255.255.252
encapsulation ppp
dialer remote-name ABC
dialer string 0514409044
dialer pool 1
dialer-group 1
ip route 192.168.223.0 255.255.255.240 Dialer0
smothuku Wed, 02/28/2007 - 23:12
Hi ,
Have you configured username XXXX password XXXX on both routers as you are using chap for authentication.
Make the following changes and check the isdn status.
Router ABC
username XXXX (router XYZ hostname) password XXXX
interface Serial1
bandwidth 2048
backup delay 1 1
interface BRI0
no ip address
encapsulation ppp
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
ip route 192.168.223.16 255.255.255.240 Dialer1 130
Router XYZ
username XXXX (router ABC hostname) password XXXX
interface Serial0
bandwidth 2048
no ip route-cache
no ip mroute-cache
backup delay 1 1
interface BRI0
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
interface Dialer0
encapsulation ppp
dialer caller 0514409044
dialer pool 1
dialer-group 1
ip route 192.168.223.0 255.255.255.240 Dialer0 130.
Try to dial from router abc to router xyz...I changed dialer string to dialer caller under di0 of router xyz so that router abc can dial router xyz.
You are using isdn as a back up for serial so use floating static routes for isdn.I've added AD value of 130 at the end of ip route.
still you are facing the problem , paste the output of " debug isdn q931"
check the below link.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_command_reference_chapter09186a00800ca52a.html
satish
afzaalq007 Wed, 02/28/2007 - 23:48
hi
thanks for the ans i will chk and will tell you the results.
one thing more I have usermane and password on the my router we are using them so want to ask you e,g on router ABC have follwing user name and passwords and same onthe xyz.
username zubair password ***
username admin1 privilege 9 password ***
will these work or not should i define more username and password fo r dialer CHAP ?????
waiting for ur response
Thanks and regaards
smothuku Wed, 02/28/2007 - 23:57
Hi ,
I think the username and passwords configured on both routers are for users who are accessing those routers , not for isdn call authentication.
Configure the following things on both routers.
Router ABC :
username XXXX (hostname of router XYZ) password XXXX.
Router XYZ
username XXXX(hostname of router ABC) password XXXX.
Note : password must be same on both routers and username must be hostname of the other end router.
dialer-remote name XXXX configured under dialer interface and username XXXX must be same.
satish
