02-28-2007 11:33 PM - edited 03-05-2019 02:38 PM
i need the command lines to port forward the port which i know by heart and i my ip address which i know by heart as well!!! i just bought a soho 97 and it is awsome but i have no clue on how to port forward with it!!! here is my router's configuration...
Cisco#sh run
Building configuration...
Current configuration : 1266 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco
enable secret ***
enable password ***
no ip subnet-zero
ip dhcp excluded-address 10.10.10.1
ip dhcp pool CLIENT
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 196.1.69.100 196.1.69.99 168.187.5.14
lease 0 2
no aaa new-model
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode ansi-dmt
hold-queue 224 in
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname ***
ppp chap password ***
ip nat inside source list 2 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
access-list 2 permit 10.10.10.0 0.0.0.255
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line aux 0
line vty 0 4
exec-timeout 120 0
password ***
login
scheduler max-task-time 5000
end
03-01-2007 04:52 AM
if internal host is 10.10.10.10 and I want to redirect telnet to that host:
ip nat inside source static tcp 10.10.10.10 23 interface dialer0 23
if internal host is 10.10.10.10 and I want to redirect telnet to that host, but my host runs telnet on port 50:
ip nat inside source static tcp 10.10.10.10 50 interface dialer0 23
if internal host is 10.10.10.10 and I want to redirect an UDP application to that host on port 60:
ip nat inside source static udp 10.10.10.10 60 interface dialer0 60
03-01-2007 04:57 AM
And change your vty password, since everyone can see it's "kemsdsl"
