PIX 525 Active/Active license
Feb 28th, 2007
Dear sir,
i have a PIX-525-UR-BUN Firewall and i want to add a new Active/Active device
what is the part number license for this new device
thanks
hoogen_82 Wed, 02/28/2007 - 23:59
This is the part code PIX-525-AA-GE-BUN.
Cisco PIX 525 Active/Active Failover two GE + two FE Bundle (chassis, failover Active/Active license, software, two Gigabit Ethernet + two 10/100 interfaces, VAC or VAC+)
The site where you can look into for other part codes to http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_data_sheet09186a0080091b09.html
Hoogen
Do rate if this helps :)
justanas1 Thu, 03/01/2007 - 00:11
but i have this bundle
PIX-525-UR-BUN with 8 FE not GE Bundle
hoogen_82 Thu, 03/01/2007 - 01:24
Really sorry. Did'nt see that.
I dont see any upgrade options for the same. I guess when u got that bundle u must have bought a FO license for another PIX.
If you have a FO license u can upgrade it from PIX 525 FO to FO-AA Platform License Upgrade PIX-525-SW-FO-AA
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_data_sheet09186a00800b0d85.html
The link would also help u out.
Hoogen
