03-01-2007 02:03 AM - edited 03-10-2019 03:01 PM
Hi everyone,
I have the problem that Cisco routers and switches do not send some accounting command
information to ACS.
Accounting commands do not send to ACS are "show log" and "show version".
Accounting commands send to ACS are "show runn", "conf t" and "debug"
The configuration of routers and switches is the following
aaa new-model
aaa authentication login default group tacacs+ line
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
tacacs-server host xxx.xxx.xxx.xxx key yyyy
I think the commands do not send to ACS are privilege level 1 command and the commands
send to ACS are privilege level 15 command.
So I need to additional aaa accounting command below to get routers and switches send level 1
command to ACS, because the "15" of "aaa accounting commands 15" does not include level 1
so need to configure "aaa accounting commands 1" for level 1 commands.
aaa accounting commands 1 default start-stop group tacacs+
Is my understanding correct ?
Your information would be greatly appreciated.
Best regards,
03-01-2007 03:51 AM
plese do this and the router will send
everything to the ACS server, except
whatever you are doing to the router in http:
aaa new-model
aaa authentication login notac none
aaa authentication login VTY group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec notac none
aaa authorization exec VTY group tacacs+ if-authenticated none
aaa authorization commands 0 VTY group tacacs+ if-authenticated none
aaa authorization commands 1 VTY group tacacs+ if-authenticated none
aaa authorization commands 15 VTY group tacacs+ if-authenticated none
aaa authorization network VTY group tacacs+ if-authenticated none
aaa accounting exec VTY start-stop group tacacs+
aaa accounting commands 0 VTY start-stop group tacacs+
aaa accounting commands 1 VTY start-stop group tacacs+
aaa accounting commands 15 VTY start-stop group tacacs+
aaa accounting network VTY start-stop group tacacs+
aaa accounting connection VTY start-stop group tacacs+
aaa session-id common
ip http authentication aaa login-authentication VTY
ip http authentication aaa exec-authorization VTY
tacacs-server host 192.168.15.10 key 7 1446405858517C
tacacs-server directed-request
line con 0
exec-timeout 0 0
accounting exec VTY
logging synchronous
login authentication notac
line aux 0
session-timeout 35791
exec-timeout 35791 23
accounting exec VTY
transport input all
line vty 0
exec-timeout 0 0
accounting exec VTY
login authentication VTY
David
CCIE Security
03-01-2007 05:57 AM
What you mentioned is correct.
Since you did not have level 1 command accounting enabled "show log" etc did not get sent to the ACS.
Adding level 1 accounting would solve the problem.
Vivek
03-01-2007 04:36 PM
Hi all,
Thank you very much for your reply.
I understand it !
Best regards,
