IVR funtionality
Mar 1st, 2007
Where and how are abandoned calls recorded?
Can someone explain the flow?
Overall Rating: 3 (1 ratings)
lpezj Thu, 03/01/2007 - 03:45
Are you referring to IPCC Express or only IP/IVR?
In Cisco IPCC Express a abandoned call is a call that it has not been handled by an agent.
In Cisco IPIVR to reflect that the call has been well managed by IP/IVR you need to change, in the script that manages the call the parameter 'Handle' to true.
Hope this helps,
Juan Luis
abhishek2525 Thu, 03/01/2007 - 04:05
Am sorry was not specific enough.
Well i am looking at the IVR in the hosted or Enterprise IPCC environment. When the call lands on the IVR and the agents are busy for a long time, the caller may hang up. Now i need to know where and how are the following parameters stored?
1.How long did the Caller hold?
2.How many calls have been abandoned in the last x seconds where x is a value that i want to control
3.Other information about the abandoned call like CLID, DN and CED ?
Zin.Karzazi Thu, 03/01/2007 - 03:48
Question is not clear, i assume u are using IPCC enterprise? what do you mean with recorded? how is your Callflow organized using ICM script?
Zin.Karzazi Thu, 03/01/2007 - 05:13
Webview_ Calltype05 (Avg wait Aban)
Webview_ Calltype35 / Calltype36
Best thing is to use SQL Analyzer.
abhishek2525 Fri, 03/02/2007 - 01:20
I am looking at the network location where this data is stored. I mean which database. Also correct me if i am wrong. Following are the types of databases in the network
1.Customer Profile Database- cust a/c info
2.Logger database - Real time data and scripts
3.Call Detail Records - All details about the call as logged by the CCM.
lpezj Fri, 03/02/2007 - 01:30
All the data managed by Webview are stored in the Distributor. For historical purpouses, the data is stored on the HDS database in the distributor.
Juan Luis
Zin.Karzazi Fri, 03/02/2007 - 02:25
Also on your DAW you should check the Schema Help (ICM Admin Workstation->Schema Help)all Tables are listed there, use the serach funktion of a schema Help+ Search funktion of Webview and you ll get what you want ;)
