Clock on pix515e
Answered Question
j have a pix 515e Version 6.1, after a current interruption I cannot set the clock of the pix, the command j have used is :
clock set 21:0:0 apr 1 2000
clock set 21:00:00 apr 01 2000
clock set 21:0:0 1 apr 2000
clock set 21:00:00 01 apr 2000
the configuration is remained correct, but without the correct clock I do not acces to the web configuration
thanks
Correct Answer by suschoud about 9 years 7 months ago
that's awkward.did u put in the commands in configuration mode .I guess u did n't.
you should be in the configuration mode to run these commands:
pix(config)#clock....
Overall Rating: 5 (1 ratings)
suschoud Fri, 03/02/2007 - 11:52
Set the PIX Firewall clock for use with the PIX Firewall Syslog Server and the Public Key Infrastructure (PKI) protocol. (Configuration mode.)
clock
clock set hh:mm:ss month day year
clock set hh:mm:ss day month year
show clock
hh:mm:ss
The current hour:minutes:seconds expressed in 24-hour time; for example, 20:54:00 for 8:54 pm. Zeros can be entered as a single digit; for example, 21:0:0.
month
The current month expressed as the first three characters of the month; for example, apr for April.
day
The current day of the month; for example, 1.
year
The current year expressed as four digits; for example, 2000.
You can interchange the settings for the day and the month; for example, clock set 21:0:0 1 apr 2000.
A time prior to January 1, 1998 or after December 31, 2097 will not be accepted (the maximum date that the clock command can work to).
While the PIX Firewall clock is year 2000 compliant, it does not adjust itself for daylight savings time changes; however, it does know about leap years.
The PIX Firewall clock setting is retained in memory when the power is off by a battery on the PIX Firewall unit's motherboard. Should this battery fail, contact Cisco TAC for a replacement PIX Firewall unit.
Correct Answer
suschoud Mon, 03/05/2007 - 06:11
