ezpn with 877 for remote and 2800 for server
I have configured Ezvpn with 877 for remote site and 2800 for server. 877 is connected to internet over adsl.
877 can establish ezvpn session to server succesfully but when I tracroute from 877 to internet it goes through adsl network instead of vpn. I think the first hop should be my ezvpn server.
I check the ezvpn connection by
sh ip route
and
sh crypto ipsec client ezvpn
and sh crypto ipsec sa
and i am sure that vpn is established.
I also test all modes ( client and netw ext and network ext plus). it is same for all
Thanks in advance for your help
ggilbert Thu, 03/01/2007 - 14:08
Do you have split tunneling enabled?
If split tunneling was enabled, you will have an acl underneath the group configuration.
You would see this if split tunneling was enabled.
Cheers
Gilbert
Rate this post, if it helps!!
