03-01-2007 07:20 AM - edited 07-03-2021 01:43 PM
hi
i have a wlan with nineteen Aps i just added a CISCO ACS SE that authentictes from the windows AD...the problem is that ever since addind the ACS my clients keeps on disconnecting and then i will be prompted to enter my credentials again,this happens in intervals of 10 minutes...what could be the problem ?
03-01-2007 08:34 AM
What version of ACS are you using, I had the same problem with ACS 4.0 upgraded to 4.1(1) Build 23 no problems since. Check your Database Replication times that could cause the radius server not found error. And option [026/5842/001] Cisco-Aironet-Session-Timeout.
03-01-2007 08:49 AM
You can try adding the Session Timeout attribute and setting a high value on it in the group/user profile.
Session Timeout is a RADIUS (IETF) attribute.
Vivek
03-01-2007 09:26 PM
but we i am not using radius IETF i am using radius Aironet.
03-03-2007 07:36 AM
When you use any Radius (Aironet or IOS etc.) you are using Radius IETF + some Cisco specific attributes.
Vivek
03-02-2007 08:23 AM
If you use PEAP authentication, you need install this hotfix on client computers:
http://support.microsoft.com/kb/885453/en-us
Zhenning
