scheduling switch reloads with LMS 2.6?
Mar 1st, 2007
Hi all,
I've staged a number of IOS switches (2950s, 3750s) with the latest firmware available. I'd like to use Ciscoworks to reload these switches either by issuing an immediate or delayed reload.
Where in Ciscoworks can I do this? Through netconfig? Or is there some other way to do this through netshow?
Joe Clarke Thu, 03/01/2007 - 09:08
Netconfig is the way. A pre-built template to do reloads is coming in LMS 3.0, but for now, you can build an ad hoc template to do what you need. Something like:
reload
Should work provided the config has already been saved. If you need to add other responses, think of as "response to follow." If the response can be just a carriage return, you can leave the text after empty.
