VPN Working however some Apps Not from Remote
Mar 1st, 2007
I posted here and got such a good response to my last issue - I hope I am not being a pest.
** Main Location no issues out to internet
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto map bhsn 10 ipsec-isakmp
description VPN to PARC
set peer X.X.X.X
set transform-set myset
match address 100
crypto map bhsn 20 ipsec-isakmp
description VPN to Corneilia
set peer X.X.X.X
match address 102
crypto map bhsn 30 ipsec-isakmp
description VPN to OAK
set peer X.X.X.X
match address 103
crypto map bhsn 40 ipsec-isakmp
description VPN to Wells
set peer X.X.X.X
match address 104
interface FastEthernet0
description inside interface
interface FastEthernet4
description 5Mb WAN to Primelink
ip address X.X.X.X 255.255.255.128 secondary
no ip unreachables
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
crypto map bhsn
interface Vlan1
description Default Gateway fa0-fa3
ip address 2X.X.X.X 255.255.255.248 secondary
ip address 192.168.0.11 255.255.255.0
no ip unreachables
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1100
ip classless
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map nonat interface FastEthernet4 overload
logging trap debugging
access-list 100 permit ip any 192.168.1.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 102 permit ip any 192.168.6.0 0.0.0.255
access-list 103 permit ip any 192.168.7.0 0.0.0.255
access-list 104 permit ip any 192.168.5.0 0.0.0.255
access-list 105 permit tcp any any eq 9903
access-list 105 permit tcp any any eq 9902
access-list 105 permit tcp any any eq 9901
access-list 105 permit udp any any eq 9901
access-list 105 permit udp any any eq 9902
access-list 105 permit udp any any eq 9903
no cdp run
route-map nonat permit 10
match ip address 101
The Remote Routers however can't seem to get trace route, and the accounting program isn't working, POP3 Mail, and Updates. Here is the config for one of the Remotes.
description WAN connection to PrimeLink$FW_OUTSIDE$
ip address X.X.X.X 255.255.255.224
duplex auto
speed auto
crypto map bhsn
interface Vlan1
description Default Gateway fa0-fa3$FW_INSIDE$
ip address 192.168.1.2 255.255.255.0
ip directed-broadcast
ip tcp adjust-mss 1452
ip classless
ip http server
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit tcp any any eq 9901
access-list 101 permit tcp any any eq 9902
access-list 101 permit tcp any any eq 9903
access-list 101 permit udp any any eq 9901
access-list 101 permit udp any any eq 9902
access-list 101 permit udp any any eq 9903
no cdp run
kaachary Sun, 03/04/2007 - 05:03
You need to give us more information about the problem. Are you able to ping across the tunnel ?
Which ip address you are doing a traceroute to..? Where does it go ?
-Kanishka
cozyk1515 Mon, 03/05/2007 - 12:17
Here is more information:
Have 4 remote locations and 1 main.
**Currently Remotes can't access each other not even ping. IE from remote 1: 192.168.1.X can't ping remote 192.168.3.X.
All Remotes can access Main location. All internet traffic has to go through main router. 192.168.0.11
** POP MAIL can't be accessed from Remotes.
** Account Software can't be used at remotes. The accounting software is installed on local machines but access information from request2.paydata.com and request.paydata.com remotes can't trace to this fails at main router.
kaachary Mon, 03/05/2007 - 12:29
Couldn't find 192.168.3.0 in the config you pasted. Assuiming, its one of the remote n/w , you are missing the deny statements in the access-list 101. e.g.
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 101 deny ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
You have to put the similar statements for every remote router.
*Please rate if helped.
-Kanishka
cozyk1515 Mon, 03/05/2007 - 14:19
Thanks for that help however what about not being able to access certain items like the accounting software and Pop Mail which should all come from the main router? All internet traffic needs to go through the main router. I tried putting in the ports for the accounting software but that didn't work. Am I missing something to allow the accounting software?
kaachary Mon, 03/05/2007 - 15:49
On the vlan in terface on Main router, the tcp mss is set to a very low value. Some applications require the packet size to be greater.
interface Vlan1
exit
Try increasing the tcp mss size to see if there's any success.
-Kanishka
cozyk1515 Mon, 03/05/2007 - 18:26
bumped
ip tcp adjust-mss 1400
Still no luck if I bump any more can't get into database that is at main site from the remote.
database gives socket error. They said check ports which I have open on both ends.
