can't change console baud rate for router 2600
Mar 1st, 2007
Break at boot rom, issue command "confreg 0x2102". After reset, the baud rate is still 115200. Show ver, it shows: "Configuration register is 0x2102 (will be 0x3922 at next reload)" confused
Overall Rating: 5 (1 ratings)
ahmednaas Thu, 03/01/2007 - 09:44
Try the following:
r#config t
r(config)#config-register 0x2102
r(config)#end
r#copy run start
r#reload
Amit Singh Thu, 03/01/2007 - 10:16
What is the exact problem you are talking about. Is it configuration register problem or console baud rate problem. Please give a clear explanation of the problem.
-amit singh
Amit Singh Thu, 03/01/2007 - 09:49
Check under the lin Con 0, if the baud rate is 115200. Change it there are 9600. Try reloading the router and check what happens.Please paste the router config.
-amit singh
xiaoliangyue Thu, 03/01/2007 - 10:47
I was trying to reset the baud rate of console to 9600, so I tried to set conf-reg, but the register always keeps 0x3922. Getting your hint, I checked the speed for console, it was 115200 in running config. After it was changed to 9600, and rebooting, the register is 0x2102 now.
Appreciate your help!
