E1 PRI integration using QSIG
Mar 1st, 2007
Does anybody has a sample config of how to interconnec an E1 PRI at 2801 to an E1 PRI at one PBX Hicom 300 using QSIG? This implementation will be done at Brazil.
Overall Rating: 5 (2 ratings)
t.silva Thu, 03/01/2007 - 10:28
It's a example:
controller E1 0/0
pri-group timeslots 1-31
interface Serial0/0:15
no ip address
no logging event link-status
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
Paolo Bevilacqua Thu, 03/01/2007 - 10:33
There are just two settings that are general and mandatory, one is "switch-type qsig", either network or user side, and the other is under "voice service voip", "qsig decode" to pass name display. All the rest must be configured locally depending on what exactly are you doing.
There are numerous config examples that you can search here with the keywords hicom 300, qsig, etc...
Steffen.Baier Mon, 03/05/2007 - 04:44
What Ecma Version are you going to be using ?
Ecma1 or EcmaV2 as the ISDN BChannel Command depends on this one.
I am on a course this week but I post my config as I spend numerous hours getting it right. Last hurdle for me is now the connected number as this shows at present only my 5 digit extension.
Steff
Steffen.Baier Tue, 03/06/2007 - 08:51
I dig this info out tonight as I am just on a CCNA Boot Camp.
I work for an Cisco Partner
I did not get any real support of cisco but I used to work for siemens so knowledge of both systems came handy.
Speak soon
Steffen.Baier Tue, 03/06/2007 - 14:14
OK,
as pomised ! I can only recommend EcmaV2 Qsig and then you must use the isdn contiguous-bchan or any call hitting B-Channel 15 to 30 will not work.
We had the following issues with Call Manager 4.2 (3) via our 37xx Routers on EcmaV1:
Calls from CCM to any Hicom and hitting a CFNA were only able to speak for 6 seconds then got disconnected.
Calls from Hicom to CCM with a CFB got busy and not another extension or VM
No Names being transmitted etc. and a lot of other issues.
Here are the general Hicom settings but you will need to adopt them to your config !
We use fully International Numbering plan and I have changed the numbers ;-)
LRTG, KNNR, LBER, KNNR, depend on the location
Important is the LDPLN in connction with the LODR
Allgemein
to reach LDN
90 is the Bund to the provider( IPC or CISCO )
6 is rollover PSTN
within LDAT is a seperation between DEE / SPR optional ( is not really needed!!! )
Important:LODR
44 is being send first and TON is internat !!
ADD-LDPLN:0-W-00-44-207-12-5-X,0&1&2&3&4&5&6&7&9,814&814&814&814&814&814&814&815&814,3,;
/// ADD-LDAT:LROUTE=814,LSVC=VCE,LVAL=1,TGRP=90,ODR=1054,LAUTH=8,CARRIER=2,ZONE=EMPTY,LATTR=NONE,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=814,LSVC=VCE,LVAL=1,TGRP=6,ODR=1054,LAUTH=1,CARRIER=3,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-6,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=814,LSVC=DTE,LVAL=1,TGRP=90,ODR=1054,LAUTH=8,CARRIER=1,ZONE=EMPTY,LATTR=NONE,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=814,LSVC=DTE,LVAL=1,TGRP=6,ODR=1054,LAUTH=1,CARRIER=3,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-6,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=815,LSVC=VCE,LVAL=1,TGRP=90,ODR=1054,LAUTH=8,CARRIER=2,ZONE=EMPTY,LATTR=NONE,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=815,LSVC=VCE,LVAL=1,TGRP=6,ODR=1054,LAUTH=1,CARRIER=3,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-6,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=815,LSVC=VCE,LVAL=1,TGRP=1,ODR=1054,LAUTH=1,CARRIER=2,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-2,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-RICHT:MODE=LRTENEW,LRTE=814,LSVC=VCE,NAME="PSTN ",TGRP=1&90&6,DNNO=1-0-0,DTMFCNV=FIX,DTMFDISP=DIGITS,DTMFTEXT="MFVWAHL ",DTMFPULS=PP300,ROUTATT=NO,EMCYRTT="",INFO=NEUTRAL;
/// ADD-RICHT:MODE=LRTEEXT,LRTE=814,LSVC=DTE,TGRP=1&6&90;
/// ADD-RICHT:MODE=LRTENEW,LRTE=815,LSVC=VCE,NAME="PSTN ",TGRP=1&90&6,DNNO=1-0-0,DTMFCNV=FIX,DTMFDISP=DIGITS,DTMFTEXT="MFVWAHL ",DTMFPULS=PP300,ROUTATT=NO,EMCYRTT="",INFO=NEUTRAL;
ADD-LODR:ODR=1054,CMD=ECHO,FIELD=4;
ADD-LODR:ODR=1054,CMD=ECHOALL;
ADD-LODR:ODR=1054,CMD=NPI,NPI=ISDN,TON=INTERNAT;
ADD-LODR:ODR=1054,CMD=END;
Steffen.Baier Tue, 03/06/2007 - 14:15
97769 is a code to get to our office in the uk via a shortdial
ADD-LDPLN:97769-X,0&1&2&3&4&5&6&7&8&9,811&811&811&811&811&811&811&812&812&811,1,;
/// ADD-LDAT:LROUTE=811,LSVC=ALL,LVAL=1,TGRP=90,ODR=812,LAUTH=8,CARRIER=2,ZONE=EMPTY,LATTR=NONE,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=811,LSVC=ALL,LVAL=1,TGRP=6,ODR=812,LAUTH=1,CARRIER=3,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-6,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=812,LSVC=ALL,LVAL=1,TGRP=90,ODR=812,LAUTH=8,CARRIER=1,ZONE=EMPTY,LATTR=NONE,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-RICHT:MODE=LRTENEW,LRTE=811,LSVC=ALL,NAME="CN-QSIG ",TGRP=1&90&6,DNNO=1-0-0,DTMFCNV=FIX,DTMFDISP=DIGITS,DTMFTEXT="MFVWAHL ",DTMFPULS=PP300,ROUTATT=NO,EMCYRTT="",INFO=NEUTRAL;
/// ADD-RICHT:MODE=LRTENEW,LRTE=812,LSVC=ALL,NAME="CN-QSIG ",TGRP=90,DNNO=1-0-0,DTMFCNV=FIX,DTMFDISP=DIGITS,DTMFTEXT="MFVWAHL ",DTMFPULS=PP300,ROUTATT=NO,EMCYRTT="",INFO=NEUTRAL;
ADD-LODR:ODR=812,CMD=OUTPULSE,DGTS=4420747;
ADD-LODR:ODR=812,CMD=ECHO,FIELD=2;
ADD-LODR:ODR=812,CMD=NPI,NPI=ISDN,TON=INTERNAT;
ADD-LODR:ODR=812,CMD=END;
Attentand Console:
Via the network we use 442071291 were 91 is the Number of the AC
PSTN is 442071234568
ADD-LDPLN:0-W-00-44-207-1234568,0&1&2&3&4&5&6&7&9,816&816&816&816&816&816&816&810&816,3,;
/// ADD-LDAT:LROUTE=816,LSVC=VCE,LVAL=1,TGRP=90,ODR=810,LAUTH=8,CARRIER=1,ZONE=EMPTY,LATTR=NONE,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=816,LSVC=VCE,LVAL=1,TGRP=6,ODR=1054,LAUTH=1,CARRIER=3,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-6,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=816,LSVC=VCE,LVAL=1,TGRP=1,ODR=1054,LAUTH=1,CARRIER=2,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-2,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=816,LSVC=DTE,LVAL=1,TGRP=6,ODR=1054,LAUTH=1,CARRIER=3,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-6,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=816,LSVC=DTE,LVAL=1,TGRP=1,ODR=1054,LAUTH=1,CARRIER=2,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-2,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=810,LSVC=VCE,LVAL=1,TGRP=90,ODR=810,LAUTH=8,CARRIER=2,ZONE=EMPTY,LATTR=NONE,DNNO=1-0-0,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-RICHT:MODE=LRTENEW,LRTE=816,LSVC=VCE,NAME="PSTN ",TGRP=1&90&18&6,DNNO=1-0-0,DTMFCNV=FIX,DTMFDISP=DIGITS,DTMFTEXT="MFVWAHL ",DTMFPULS=PP300,ROUTATT=NO,EMCYRTT="",INFO=NEUTRAL;
/// ADD-RICHT:MODE=LRTEEXT,LRTE=816,LSVC=DTE,TGRP=1&6;
/// ADD-RICHT:MODE=LRTENEW,LRTE=810,LSVC=VCE,NAME="PSTN ",TGRP=90,DNNO=1-0-0,DTMFCNV=FIX,DTMFDISP=DIGITS,DTMFTEXT="MFVWAHL ",DTMFPULS=PP300,ROUTATT=NO,EMCYRTT="",INFO=NEUTRAL;
ADD-LODR:ODR=810,CMD=OUTPULSE,DGTS=442071291;
ADD-LODR:ODR=810,CMD=NPI,NPI=ISDN,TON=INTERNAT;
ADD-LODR:ODR=810,CMD=END;
ADD-LDPLN:97769-91,0&1&2&3&4&5&6&7&8&9,813&813&813&813&813&813&813&812&812&813,1,;
/// ADD-LDAT:LROUTE=813,LSVC=ALL,LVAL=1,TGRP=90,ODR=814,LAUTH=8,CARRIER=1,ZONE=EMPTY,LATTR=NONE,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=813,LSVC=ALL,LVAL=1,TGRP=6,ODR=814,LAUTH=1,CARRIER=3,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-6,VCCYC=KEINE,CBMATTR=1,SCCID=4;
/// ADD-LDAT:LROUTE=813,LSVC=ALL,LVAL=1,TGRP=1,ODR=814,LAUTH=1,CARRIER=2,ZONE=EMPTY,LATTR=WCHREG,DNNO=2-3-2,VCCYC=KEINE,CBMATTR=1,SCCID=4;
ADD-LODR:ODR=814,CMD=OUTPULSE,DGTS=442071234568;
ADD-LODR:ODR=814,CMD=NPI,NPI=ISDN,TON=INTERNAT;
ADD-LODR:ODR=814,CMD=END;
To reach the German Attendand Console you dial the 0 at the end
Important :LODR
49 is being send first and TON is internat !!
ADD-LDPLN:0-W-123-0,0&1&2&3&4&5&6&7&8&9,219&219&219&219&219&219&219&218&218&219,,3,,,,NEIN;
/// ADD-LDAT:LROUTE=219,LSVC=VCE,LVAL=1,TGRP=90,ODR=1033,LAUTH=8,CARRIER=4,ZONE=EMPTY,LATTR=NONE,VCCYC=4;
/// ADD-LDAT:LROUTE=219,LSVC=VCE,LVAL=1,TGRP=1,ODR=1033,LAUTH=8,CARRIER=4,ZONE=EMPTY,LATTR=NONE,VCCYC=4;
/// ADD-LDAT:LROUTE=219,LSVC=DTE,LVAL=1,TGRP=1,ODR=1033,LAUTH=1,CARRIER=7,ZONE=EMPTY,LATTR=WCHREG,DNNO=8-5-701,VCCYC=4;
/// ADD-LDAT:LROUTE=218,LSVC=VCE,LVAL=1,TGRP=1,ODR=1033,LAUTH=1,CARRIER=7,ZONE=EMPTY,LATTR=WCHREG,VCCYC=4;
/// ADD-LDAT:LROUTE=218,LSVC=DTE,LVAL=1,TGRP=1,ODR=1033,LAUTH=1,CARRIER=7,ZONE=EMPTY,LATTR=WCHREG,VCCYC=4;
/// ADD-RICHT:MODE=LRTENEW,LRTE=219,LSVC=VCE,NAME="",TGRP=90&1,DNNO=8-5-100,DTMFCNV=FIX,DTMFDISP=DIGITS,DTMFTEXT="MFVWAHL ",DTMFPULS=PP300,PLB=NO,ROUTATT=NO,EMCYRTT=NO,INFO="",PDNNO=0,CONFTONE=NO,RERINGRP=NO,NOPRCFWD=NO,NITO=NO;
/// ADD-RICHT:MODE=LRTEEXT,LRTE=219,LSVC=DTE,TGRP=1;
/// ADD-RICHT:MODE=LRTENEW,LRTE=218,LSVC=VCE,NAME="",TGRP=1,DNNO=8-5-701,DTMFCNV=FIX,DTMFDISP=DIGITS,DTMFTEXT="MFVWAHL ",DTMFPULS=PP300,PLB=NO,ROUTATT=NO,EMCYRTT=NO,INFO="",PDNNO=0,CONFTONE=NO,RERINGRP=NO,NOPRCFWD=NO,NITO=NO;
ADD-RICHT:MODE=LRTEEXT,LRTE=218,LSVC=DTE,TGRP=1;
ADD-LODR:ODR=1033,CMD=OUTPULSE,DGTS=49691230;
ADD-LODR:ODR=1033,CMD=NPI,NPI=ISDN,TON=INTERNAT;
ADD-LODR:ODR=1033,CMD=END;
ADD-LDPLN:0-W-713-1-X,0&1&2&3&4&5&6&7&9,217&217&217&217&217&217&217&218&217,,3,,,,NEIN;
ADD-LDPLN:0-W-713-2-X,0&1&2&3&4&5&6&7&9,217&217&217&217&217&217&217&218&217,,3,,,,NEIN;
ADD-LDPLN:0-W-713-6-X,0&1&2&3&4&5&6&7&9,217&217&217&217&217&217&217&218&217,,3,,,,NEIN;
/// ADD-LDAT:LROUTE=217,LSVC=VCE,LVAL=1,TGRP=90,ODR=1034,LAUTH=8,CARRIER=4,ZONE=EMPTY,LATTR=NONE,VCCYC=4;
/// ADD-LDAT:LROUTE=217,LSVC=VCE,LVAL=1,TGRP=1,ODR=1034,LAUTH=8,CARRIER=4,ZONE=EMPTY,LATTR=NONE,VCCYC=4;
/// ADD-LDAT:LROUTE=217,LSVC=DTE,LVAL=1,TGRP=1,ODR=1034,LAUTH=1,CARRIER=7,ZONE=EMPTY,LATTR=WCHREG,DNNO=8-5-701,VCCYC=4;
/// ADD-LDAT:LROUTE=218,LSVC=VCE,LVAL=1,TGRP=1,ODR=1034,LAUTH=1,CARRIER=7,ZONE=EMPTY,LATTR=WCHREG,VCCYC=4;
/// ADD-LDAT:LROUTE=218,LSVC=DTE,LVAL=1,TGRP=1,ODR=1034,LAUTH=1,CARRIER=7,ZONE=EMPTY,LATTR=WCHREG,VCCYC=4;
/// ADD-RICHT:MODE=LRTENEW,LRTE=217,LSVC=VCE,NAME="",TGRP=90&1,DNNO=8-5-100,DTMFCNV=FIX,DTMFDISP=DIGITS,DTMFTEXT="MFVWAHL ",DTMFPULS=PP300,PLB=NO,ROUTATT=NO,EMCYRTT=NO,INFO="",PDNNO=0,CONFTONE=NO,RERINGRP=NO,NOPRCFWD=NO,NITO=NO;
/// ADD-RICHT:MODE=LRTEEXT,LRTE=217,LSVC=DTE,TGRP=1;
/// ADD-RICHT:MODE=LRTEEXT,LRTE=218,LSVC=DTE,TGRP=1;
ADD-LODR:ODR=1034,CMD=OUTPULSE,DGTS=4969;
ADD-LODR:ODR=1034,CMD=ECHO,FIELD=3;
ADD-LODR:ODR=1034,CMD=ECHOALL;
ADD-LODR:ODR=1034,CMD=NPI,NPI=ISDN,TON=INTERNAT;
ADD-LODR:ODR=1034,CMD=END;
Steffen.Baier Tue, 03/06/2007 - 14:16
97000 is the code to get to germany
ADD-LDPLN:97000-X,,900,,11,,,,NEIN;
/// ADD-LDAT:LROUTE=900,LSVC=ALL,LVAL=1,TGRP=1,ODR=900,LAUTH=11,CARRIER=9,ZONE=EMPTY,VCCYC=4;
/// ADD-RICHT:MODE=LRTENEW,LRTE=900,LSVC=ALL,NAME="DRKW FFM ",TGRP=1,DNNO=18-5-700,DTMFTEXT="",ROUTATT=NO,EMCYRTT=NO,INFO="",PDNNO=0,CHARCON=NEUTRAL,CONFTONE=NO,RERINGRP=NO,NOPRCFWD=NO,NITO=NO;
ADD-LODR:ODR=900,CMD=OUTPULSE,DGTS=4969123;
ADD-LODR:ODR=900,CMD=ECHO,FIELD=2;
ADD-LODR:ODR=900,CMD=NPI,NPI=ISDN,TON=INTERNAT;
ADD-LODR:ODR=900,CMD=END;
On call manager we have set in the gateway settings that the called and the calling party number use international format.
Called and Calling Numbering Plan is ISDN
Numbers to strip are 3 (acces code and 00 international code)
Caller id dn = 441234xxxx
Please let me know if you have any more issues or questions.
The isdn contiguous-bchan is only working with EcmaV2. If you really need to run EcmaV1 you will need the other command.
Our 37xx run the following:
dial-peer voice 4969123 pots
destination-pattern 4969123
incoming called-number .
direct-inward-dial
port 4/0:15
forward-digits all
And we added to London:
dial-peer voice 4969123 voip
destination-pattern 4969123T
voice-class codec 99
session target ipv4:10.196.152.190
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
ip qos dscp cs5 signaling
