CSS connection time out from service
Mar 1st, 2007
Hi there,
I am working with a customer in Waukegan
and we are attempting to load balance
a set of J2EE web services on websphere application with a CSS Switch in front.
It seems we are having a problem when a client application that resides on the same cluster of boxes tries to call a web service on the same cluster of boxes via an https call to the CSS switch.
I have been told by the customer's networking folks that CSS won't support an application to the same virtual ip (ie: call itself in a sense.)
Can you help?
Thx very much in advance.
John Harney
gmarogi Wed, 03/07/2007 - 13:05
The CSS has a flow map of all active flows and there is a timer task running which goes through and checks each flow periodically to see if it has been idle for its idle timeout value.So a TCP becomes eligible for garbage collection at 15 seconds but it could be many seconds after that before it is actually cleaned up.
jgharney1 Wed, 03/07/2007 - 13:09
Hi there, I think you are answering a different topic. We found a solution to this issue from another forum post about HTTP and services calling themselves.
Thx,
JGH
