What is the best and quickest way to find out what host has the largest number of connections to the PIX or is hitting the PIX the most with the most traffic? THanks to all!
will give you all connections. Take this output to a file and check number of instances per host.
May be there is a better solution but this is from top of my head.
Syed Iftekhar Ahmed
