mac filtering configuration
Mar 1st, 2007
We need to configure a mac filter on a bunch of the cisco 2950 switches to allow only certain devices in. Short of manually doing it, has anybody done this in a more efficient way?
thanks
abhishek_nandavat Thu, 03/01/2007 - 23:42
What I understand is that you want only specified devices to be on your network, isnt it?
Well, what you can do is define a mac address based access control list and then apply a vlan-map to block or pass the traffic from those mac addresses.
Have a look at the following link for more -->
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_example09186a0080470c39.shtml
The following URL might help as well -->
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_guide_chapter09186a008007fa38.html#1020942
Hope this helps...
AbhisheK
Please rate helpful posts!!!
