HELP! - CUE Script Editor killing me
I am trying to use simple AA. Everything else seems to work except the "dial extension at any time" option I need.
I am using 3 digit extensions beginning with "1". Anytime you hit the number one, no matter which prompt you are in, it immediately starts dialing and gives an error.
I attached my poor excuse for a script.
PLEASE HELP
rob.huffman Fri, 03/02/2007 - 06:13
Hi Walter,
I could not open your script :( but I thought of two things. My blind guess is that you are running into a problem due to the fact that your extensions begin with 1, on the default AA script I believe 1 is set to access the directory search. Here is a good Quick start guide that may help. Also, you should post this exact question on the Unity/Unified Forum. There are some real CUE experts there who can probably figure this out.
Unity Express Custom Scripts Quick Start Guide
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008041d950.shtml
Hope this helps!
Rob
