Two ISP on one pix seprate routes
Mar 1st, 2007
How can I configure two ISP's with, each there on unnumbered ip routers, in the pix and do source routing?
vitripat Fri, 03/02/2007 - 04:06
Source routing .. unfortunately PIX cannot do source-routing.
However it seems that you are looking either for a load-balancing scenario, or simple ISP failback.
If its only load-balancing scenario, PIX cannot work as a "TRUE" load-balancer, however it can load balance the traffic based on source/destination IP. Here is how-
Assuming that ISP1's router is connected via ISP1 interface and ISP2's router is connected via ISP2 interface. Now we can configure routes on PIX like this-
route ISP1 128.0.0.0 128.0.0.0 1.1.1.1
route ISP2 0.0.0.0 128.0.0.0 2.2.2.2
1.1.1.1 - this is the router interface of ISP1
2.2.2.2 - this is the router interface of ISP2
This method is called "poor man" load-balancing.
The first creates a default route that routes addresses with the first bit of 1 to 1.1.1.1.
The second creates a default route that routes addresses with the first bit of 0 to 2.2.2.2.
Vibhor.
vitripat Fri, 03/02/2007 - 04:11
Forgot the second this.
Other thing we can do is ISP failback, i.e, if one ISP fails, traffic can be routed through different ISP. This type of configuration is only supported if you are running on OS version 7.2 or higher-
Failback of ISP works using a new feature called "Static Route Tracking".
The main problem with defining two default static routes with different AD was:
- How to determine if the route with lower AD has failed ??
- The route with lower AD will only be used if the associated interface goes down itself.
Thus, in order to make sure that the current static route is functional we needed something for monitoring
the connectivity using this route.
ICMP was used for this. With Static Route Tracking configured, PIX keeps a check on the static route
using echo-request messages.
When monitoring of a particular route fails, it is removed from the routing table and a previously configured
backup route is used in place of the removed route. A backup route can be another default route with a
higher metric than the existing one.
Following commands can be used for ISP failback:
--> pixfirewall(config)# sla monitor 20
(20 is only a ID here. Valid values are from 1 to 2147483647.)
--> pixfirewall (config-sla-monitor)# type echo protocol ipIcmpEcho 192.168.1.1 interface outside
192.168.1.1 - This is my target IP on which PIX will keep a check. There are options available
on this, but its on your discreation on what you want to keep a check on. For eg:
- We can set PIX to keep a check on some host outside which is accessible via existing static default
route I'm checking.
--> pixfirewall(config)# sla monitor schedule 20 life forever start-time now
- Above command is telling PIX to start monitoring on "sla-id 20" now (start-time now) and
continue monitoring forever (life forever).
Next, I create a "Track ID" to associate a static route entry with the SLA monitoring process.
--> pixfirewall(config)# track 200 rtr 20 reachability
(200 is the Track_id and 20 is the sla-id)
Now we will use above "TRACK" to track a static route on PIX and make sure that the static route is
working fine. This is done using following command:
-> pixfirewall(config)# route outside 0 0 192.168.1.1 1 track 200
PIX will see that a "Track ID" is associated with the static route. PIX will check the TRACK which is supposed to
track the static route as defined in "SLA", here sla-id (20).
The SLA says to monitor forever and start monitoring as soon as SLA is created and the target it will monitor
through the static route is defined above as "192.168.1.1". This was done in the following command.
To summarize:
In order to configure Static Route Tracking for a static route entered manually, following commands are
entered:
--> pixfirewall (config-sla-monitor)# exit
--> pixfirewall(config)# route outside 0 0 192.168.1.1 1 track 200
--> pixfirewall(config)# route failback 0 0 192.168.2.1 100
When it is detected that route via 192.168.1.1 has failed, route with higher metric will takeover.
Let me know if you have any questions on this.
Vibhor,
zubairjalal Fri, 03/02/2007 - 04:37
Hi Vibhor..
i have 2 queries...
1. will this also work for VPN redundancy...i.e once the primary isp goes down..the site to site vpn's should be established with the other ISP address...I know that we might have to clear the SA manually but can we decrease the timeout or the lifetime so that it automatically clears the SA...
2. I have configured ISP redundancy at one site and the problem that i faced is that If ?Redundancy Link? goes down then ?Primary Link? does not come up automatically, then we need to remove the static route of Primary Link and add it again and after that internet start working, but again for Site to SIte VPN tunnel we need to clear crypto isakmp entry and then only the VPN Tunnel establish. Please let me know if you have any inputs..
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 1.1.1.1 255.255.255.240 standby 1.1.1.2
interface GigabitEthernet0/3
nameif backup
security-level 0
ip address 2.2.2.2 255.255.255.224 standby 2.2.2.3
route outside 0.0.0.0 0.0.0.0 1.1.1.100 1 track 1
route backup 0.0.0.0 0.0.0.0 2.2.2.100 254
sla monitor 123
type echo protocol ipIcmpEcho 10.10.10.1 interface outside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
crypto map outside_map interface outside
crypto map outside_map interface backup
Please note :IP addresses have been changed.
regards
Zubair
vitripat Fri, 03/02/2007 - 04:43
For VPNs, need to clear the SAs.
Regarding route not being reinstalled, if the configuration is correct, then this should be due to a bug.
sebastan_bach Sat, 03/03/2007 - 07:48
hi vibhor i couldn;t really understand the routes u have put on the pix.
in this route where ISP1 is the exit interface 128.0.0.0 is the destination network. could u pls tell why have u choose this as the destination. and i am really confused abt the subnet masks also. i guess the turned on bits in the subnet mask only represent the bits that are used.
and why will the first route create a default route .
as we are connecting to the isp for the internet.
i am really not getting this can u pls explain.
waiting for ur reply.
regards
sebastan
a.alekseev Wed, 09/12/2007 - 08:20
sebastan,
Vibhor divied internet into two parts.
One part is going though ISP1 and another though ISP2.
route ISP2 128.0.0.0 128.0.0.0 2.2.2.2
route ISP1 0.0.0.0 128.0.0.0 1.1.1.1
a.alekseev Wed, 09/12/2007 - 08:13
In most cases the answer will be "no, you can't"
PIX doesn't support source routing.
You have to have a router in front of your piх.
