Read-only aaa statements
Mar 1st, 2007
I've setup the TACACS server with two groups
-FULL admin rights
-READ only rights
Two users have been created
-admin_test
-read_test
The admin_test config works fine on AAA but i keep getting stuck with read_test configs. I can never get to enable mode eventhough i've defined it on the group policy. Is there something wrong with my aaa statements below?
aaa authentication login default group tacacs+ line enable
aaa authentication enable default group tacacs+ enable line
aaa authorization exec default if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
daviddtran Fri, 03/02/2007 - 04:45
Privilege is not scalable in a big environment.
What you need is authorization on the ACS
server. In Cisco Freeware TACACS+ I defined
the following groups: readonly, advanced and
admin:
group = readonly {
default service = deny
cmd = show { deny .* }
cmd = show { permit .* }
cmd = copy { permit .* }
cmd = ping { permit .* }
cmd = enable { permit .* }
cmd = configure { deny .* }
cmd = disable { permit .* }
cmd = telnet { permit .* }
cmd = disconnect { permit .* }
cmd = where { permit .* }
cmd = set { permit .* }
cmd = clear { permit line }
cmd = exit { permit .* }
cmd = debug { permit .* }
group = advanced {
cmd = copy { permit flash }
cmd = copy { permit running }
cmd = configure { permit .* }
cmd = interface { permit .* }
group = admin {
default service = permit
As you can see, admin can access everything,
readonly can only read. Advanced can make
limited changes and admin can do everything.
On the Cisco router, I have the following
configuration:
aaa authentication login notac none
aaa authentication login VTY group tacacs+ local
aaa authorization console
aaa authorization config-commands
aaa authorization exec notac none
aaa authorization exec VTY group tacacs+ if-authenticated none
aaa authorization commands 0 VTY group tacacs+ if-authenticated none
aaa authorization commands 1 VTY group tacacs+ if-authenticated none
aaa authorization commands 15 VTY group tacacs+ if-authenticated none
aaa authorization network VTY group tacacs+ if-authenticated none
aaa accounting exec VTY start-stop group tacacs+
aaa accounting commands 0 VTY start-stop group tacacs+
aaa accounting commands 1 VTY start-stop group tacacs+
aaa accounting commands 15 VTY start-stop group tacacs+
aaa accounting network VTY start-stop group tacacs+
aaa accounting connection VTY start-stop group tacacs+
I find that by doing it this way, it is much
more scalable than using privilege commands
on the router itself.
David
CCIE Security
Vivek Santuka Sat, 03/03/2007 - 07:23
Hi Echelo360,
The aaa config that you pasted does not have command authorization.
You need the 3 authorization commands from david's post.
Vivek
