Getting Inventory from IP Solution Centre
Mar 2nd, 2007
Is there any way of dumping the whole of the inventory managed by IP Solution Centre to a file (XML)? I can see there is an API to get inventory on a per object basis (enumerateInstance) but I need to take a dump every week.
Overall Rating: 4.5 (2 ratings)
jreekers Tue, 04/17/2007 - 17:08
Hi.
The VpnInvExport command allows the entire ISC Repository to be exported into a flat file, however there is no way to export directly into an XML file.
