03-02-2007 03:21 AM - edited 03-18-2019 07:01 PM
Hi All
Quick query (I hope). I have a client that we have recently deployed Unity Express for. He wishes to use the IMAP desktop messaging feature. I have implemented the instructions at the folliwng link:
However, when I get to the part where it says associate a user with a group using the
username xxxxx groupname xxxxx
command, I am unable to, as when I list the subcommands available, I have three available: create, phonenumber and phonenumberE164 .
I am using a NM-CUE running version 2.3 of CUE.
Has anyone got any ideas on this one? Is the documentation wrong? Should it be a different command? Anyone run into this one?
03-02-2007 05:52 AM
Hi Marc,
In my mind it looks like the document you are using is wrong. If you followed the Summary steps 7&8 IMAP would be in the disabled state and I don't believe those prompts would be available. Have a look;
SUMMARY STEPS
1. config t
2. service imap
3. enable
4. maxsessions num-sessions
5. session idletimeout minutes
6. session security {ssl | none | mixed}
7. enable **
8. no enable **
Note Any changes to IMAP server configuration require a restart of the IMAP server for the changes to take effect. Steps 7 and 8 restart the IMAP server.
9. end
10. groupname groupname privilege vm-imap
11. username username group groupname
12. end
13. (Optional) show imap configurations
14. (Optional) show imap sessions
enable (IMAP)
To enable the integrated messaging (IMAP) feature system wide, use the enable command in Cisco Unity Express IMAP mode. To disable the IMAP feature, use the no or default form of this command.
enable
no enable
default enable
The following example enables the IMAP feature:
se-10-0-0-0# config t
se-10-0-0-0(config)# service imap
se-10-0-0-0(config-imap)# enable
From this doc;
Hope this helps!
Rob
03-02-2007 07:31 AM
Thanks for the feedback.
Just found the answer from a colleague.
One needs to use the following command syntax:
groupname xxxxx member yyyyyy
to add users to a group to enable to IMAP service.
Thanks for the reply though.
Rgds
Marc
