Client can't associate
Mar 2nd, 2007
I've AP 1121G -
here config-
dot11 ssid 354783729734
authentication open
authentication key-management wpa
wpa-psk ascii xxx
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid 354783729734
Client -Cisco PI-21AG configured via Cisco ADU -
selected WPA/WPA@ passphrase.
The client can't associate. in log i see
17: dot11_dot1x_send_ssn_eapol_key: eapol->length 95
*Mar 2 21:31:52.217: dot11_dot1x_build_ptk_handshake: building PTK msg 1 for 0040.96b1.59a5
*Mar 2 21:31:52.317: %DOT11-7-AUTH_FAILED: Station 0040.96b1.59a5 Authentication failed
*Mar 2 21:31:52.317: dot11_auth_client_abort: Received abort request for client 0040.96b1.59a5
*Mar 2 21:31:52.317: dot11_auth_client_abort: No client entry to abort: 0040.96b1.59a5 for application 0x1
Which are the possible reasons of that problem?
amritpatek Thu, 03/08/2007 - 06:34
The logs clearly indicate that the authentication is failing. Which RADIUS server are you using? And what type of EAP authentication are you using? Has the user database been created on the Radius server? For instructions on configuring WPA on the AP read the document available at http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c40b6.shtml
I have the same problem as the person above, but this doesn't seem to be a RADIUS server issue. The client will associate and authenticate when using Windows to configure the card, but using the Intel PROSet utility, it fails. Just looking for suggestions on what else to debug on the AP side. We are migrating to WPA2/PEAP with our prefered method being clients use Windows to configure the connection, but I know there are going to be those that "have" to use the utility.
andrew.brazier@... Fri, 09/21/2007 - 06:45
If you're using Intel clients, update the drivers and the utility to the latest versions. Older versions are very unstable.
Trending Topics - Security & Network
