Multicast issue and help needed
Answered Question
Mar 2nd, 2007
I have configured multicast between two sites running two Cisco 2600 router over T1 and Cisco 2948 switches behind them. I'm runing weblogic multicast with the TTL of 2 or higher. I see multicast on one end but the other end shows nothing.
My interface config look like this
interface FastEthernet0/0.3
encapsulation dot1Q 103
ip address 192.168.216.1 255.255.255.128
ip pim sparse-dense-mode
no ip route-cache
no ip mroute-cache
My other end is .129/25 and I have cgmp enabled on Cisco 2948.
Is there anything I'm missing in the configuration? Please advice.
Correct Answer by Harold Ritter about 9 years 7 months ago
Silly question but have you configured PIM on the serail link between the two sites?
Overall Rating: 5 (1 ratings)
Harold Ritter Fri, 03/02/2007 - 06:44
It is hard to comment with so little info. Did you configure a static RP or auto-RP? Can you attach the output of a show ip mroute" from the router ar the site that doesn't receive the multicast packets.
Cheers,
nawas Fri, 03/02/2007 - 06:49
Yes
Non Working router:--
Exec-2620-HB#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, C - Connected, L - Local, P - Pruned
R - RP-bit set, F - Register flag, T - SPT-bit set, J - Join SPT
M - MSDP created entry, X - Proxy Join Timer Running
A - Candidate for MSDP Advertisement
Outgoing interface flags: H - Hardware switched
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.0.1.40), 1d00h/00:00:00, RP 0.0.0.0, flags: DJCL
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
FastEthernet0/0.3, Forward/Sparse-Dense, 1d00h/00:00:00
Working Router:--
dc-3620-Hb#sh ip mroute
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report
(*, 237.0.0.96), 20:52:57/00:02:59, RP 0.0.0.0, flags: DC
FastEthernet0/0.3, Forward/Sparse-Dense, 20:52:57/00:00:00
(192.168.216.4, 237.0.0.96), 00:02:59/00:00:00, flags: PCT
Incoming interface: FastEthernet0/0.3, RPF nbr 0.0.0.0
Outgoing interface list: Null
(192.168.216.5, 237.0.0.96), 00:00:39/00:02:20, flags: PCT
(*, 224.0.1.40), 1d00h/00:00:00, RP 0.0.0.0, flags: DCL
Correct Answer
Harold Ritter Fri, 03/02/2007 - 06:55
nawas Fri, 03/02/2007 - 07:32
Not a silly question because this is something I missed. It now works when enabled on serial interface. Thanks a lot
