Phone firmware and DST...
Mar 2nd, 2007
For my 7911G's, Im required to update phone firmware to "8.0(4)SR3 or 8.2(1)" for DST.
When I view the webpage for my phone, I see "App load ID", "Boot load ID", "Version".....
Well which exactly is the "phone firmware" ???
Overall Rating: 5 (3 ratings)
rob.huffman Fri, 03/02/2007 - 07:08
Hi Cody,
On the phone webpage it will be shown as version. I just checked one out to be sure.
Hope this helps!
Rob
Brandon Buffin Fri, 03/02/2007 - 07:09
The Version corresponds to firmware 8.2(1), for example.
Hope this helps. If so, please rate the post.
Brandon
censanian Fri, 03/02/2007 - 07:43
Ok... so on my phones webpage i see...
" Version SCCP11.8-0-3S "
So I should be ok with the whole DST issue then?
censanian Fri, 03/02/2007 - 07:53
Ah ok, didnt know if u was supposed to ignore that leading "11" or not - thanks!
