CCM - Phone load file duplicates: term41.default.loads
I'm new to CCM and I am trying to update the phone load on 2 stations for testing. I know I need to add the downloaded files to the TFTPPath directory but there are 2 files that already exist, term41.default.loads and term61.default.loads.
Should these files be over written? I am just trying to test load 8-2-1 for DST.
Greg
mchandak Fri, 03/02/2007 - 08:00
that is the default load which is shipped with CallManager and you should not play with that one. When you add a new Firmware, the Filename of that would be different. It would not be the same. The most simple option to update the firmware would be download the exe version of the firmware update and run it on the TFTP Server (If it is a CallManager) and that would update the file at TFTP Path and the configuration at the same time. All you would have to do is reset the phones after this
rob.huffman Fri, 03/02/2007 - 10:53
Hi Greg,
I know what you are saying here :) that would be a bad deal upgrading Firmware unexpectedly. I think the best way to do this is to use the individual firmware files that are included in the .zip file. Then load it on the TFTP server and apply to the phones you want to test with. After you are satisfied you can go ahead and load the firmware in the "device defaults" page and upgrade the rest of the phones.
Hope this helps!
Rob
twissam Mon, 03/05/2007 - 23:25
i have a similar problem, i am trying to do this test with 7970, i do not want to use the .exe file instead the .zip, but i am wondering on the device page which file to call.
Good day
Zin.Karzazi Tue, 03/06/2007 - 00:51
the load you should put in the device page for testing is : SCCP70.XX
bbalanetsky Wed, 03/07/2007 - 06:29
We wanted to do testing before rolling the firmware out to all phones, so I copied the zip version of the code to the tftp directory, restarted the tftp service thru CM, then put the load name (ie sccp41.8-2-1s) directly on the phone configuration page. Reset the phone and it loads the new code.
Hope this helps
The same worked for me, except I ended up putting the entire zip file on a different tftp server. On the phone configuration page there are 2 fields that I used to control the phone load. 1st field is the "phone load name" where I put the name of the new load file. (ie. SCCP41.8-2-1S )The next field is the "load server" where you put the name of the tftp server being used to host the files. Restart the phone to boot the test load. If you want to revert back, you simply remove the information in the 2 fields and reset the phone again and it will boot to the default load. It's pretty cool.
Thanks everybody for your help!!
-Greg
