Trace traffic On 515 firewall
Mar 2nd, 2007
I would need help on how i can trace and capture traffic on the above firewall.
i need to prove to my IS guys that the firewall has no problems.
hoogen_82 Fri, 03/02/2007 - 08:11
What kind of traffic are you trying trace..What is the problem that you are facing?
ICMP packet trace can be enabled by issuing a debug icmp trace command, to stop it enter no debug icmp trace.
Cheers
Hoogen
suschoud Fri, 03/02/2007 - 10:59
Following is the method to take captures on PIX:
Issue with communication between a client on inside interface and a server on outside interface.
Replace IP addresses appropriately-
access-list cpo permit ip host host
capture capo access-list cpo buffer 2000000 packet-length 1518 interface outside
access-list cpi permit ip host host
capture capi access-list cpi buffer 2000000 packet-length 1518 interface inside
SRC_IP : This is the original IP address of client from where request is being
generated
XSRC_IP : This is the translated IP address of the inside client. IP address to
which inside client is translated when going outbound.
DST_IP : This is the Destination IP address.
Alternatively, captures on both interfaces can be taken in a single capture file.
access-list cap permit ip host host
capture capio access-list cap buffer 2000000 packet-length 1518 interface outside interface inside
To download the captures:
using a maching with PDM access-
https://interface_IP/capture/capo/pcap
--> save file as outside.cap
(Captures on outside interface)
https://interface_IP/capture/capi/pcap
--> save file as inside.cap
(Captures on inside interface)
https://interface_IP/capture/capio/pcap
--> save file as inout.cap
(Captures on inside and outside interface)
If PDM is not available, captures can be sent to a TFTP server using following commands-
copy capture:capo tftp://x.x.x.x/outside.cap pcap
(Captures on outside interface of PIX, capture file will be saved as "outside.cap")
copy capture:capi tftp://x.x.x.x/inside.cap pcap
(Captures on outside interface of PIX, capture file will be saved as "inside.cap")
copy capture:capio tftp://x.x.x.x/inout.cap pcap
(Captures on inside and outside interface of PIX, capture file will be saved as "inout.cap")
x.x.x.x : IP address of TFTP server.
do not forget to rate this. :)
