CCM/IPCC Design question
Mar 2nd, 2007
I have a design question, I hope you can help me :
One of our customer wants that all incoming calls pass through an IPCC script
to check the holiday or opening hours, if the call arrives in the opening
hours, the script must forward the call to the original extension.
I tried this but it don't work :
I created a partition A and a CSS C (-> only the partition A is available).
The voigecateway CSS is CSS C.
I created a translation pattern : Translation Pattern : XXX ; Called Party
Transform Mask : 777
777 is the ipcc route point.
In the script, I tried to retrieve the called number or the original called
number but I get 777 instead of the original number.
I though to another idea :
create all the existing extensions in another partition and define for all
these extensions a forward all to the 777, so my script can get all the
incoming calls and can retrieve the extension to forward to.
But it's not convenient because If I have 100 extension, I have to create
100 more and it's not convenient for maintenance.
Do you have another idea to do this ?
Thanks you in advance,
Thierry
thierry.berwart_2 Thu, 03/08/2007 - 23:38
Sorry, I forgot to write that we used IPCC Express 4.0(2) and not IPCC Enterprise.
So I think that your document won't help me.
Kind regards,
Thierry
vbarreira Wed, 05/09/2007 - 04:16
Hy, i managed the same thing you want to do through a script that validates the time of day, then in one situation forwards to a extension number, if its holiday for example, forwards to another.
Hope this helps
Pedro Nogueira
thierry.berwart_2 Wed, 05/09/2007 - 05:16
Hi Pedro,
Yes but the problem for me was that we have to do this for every phone which has a DID number...
It's not imaginable to manage 100 or 300 phones ...
