Change router{s ip using SDM
Answered Question
Mar 2nd, 2007
I have a 1721 cisco router with one adsl wic installed.It has a wan address with we want to change because our ISP needs to change ....
Using SDM , which is the best way to do?If I change the ip using SDM the router will change my nat configuration from the older WAN address to the new??
Best regards
Correct Answer by spremkumar about 9 years 6 months ago
Hi Edgar
You can check out whether your actual NAT/PAT statement pointing out your interface or the ip configured on your interface.
If its pointing towards your interface i dont think you really need to change anything on the nat statements.
Also i feel your SP might have provided dynamic ip which may change time to time whenever you get connected..
regds
Overall Rating: 5 (1 ratings)
Correct Answer
spremkumar Sun, 03/04/2007 - 21:15
Hi Edgar
regds
edgar-quintana Mon, 03/05/2007 - 05:27
My ISP provides me a static IP address.
I do not understand this->You can check out whether your actual NAT/PAT statement pointing out your interface or the ip configured on your interface.
Best regards
