The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
OK, so I've got a set of ASA's and we are migrating them to Firepowers, and all seems ok. In the past we have noticed that for some reason on the ASA's, no matter what you specify as the parameters for phase 1, the rekey timer always connects at 3600...
Foro Ask Me Anything (del 25 de abril al 3 de mayo de 2024) Este foro está dedicado a las preguntas relacionadas con el webinar "Un Enfoque Práctico en NCS 540/560 y NCS 5500", del pasado jueves 25 de abril de 2024. Revisen la grabación, envíenos su...
hi i am trying to cable up trhe ucs 6454. I got 2 40G mopdules on port 53 and 54 on each fabric. I got 2 core switches to connect therm to FABRIC 1port 53 ----> port 1 on Core switch APort 54 -----> port 1 on Core Switch BFABRIC 2port 53 ------> port...
Hi all,I want to ask you experts some suggestion on how really work mechanism between Cisco switches and radius server when using dynamic vlan assignement and the radius suddenly will be unavailable.With server dead command under port configuration i...
Hello everyone,I'm trying to figure out a frustrating issue. Attempting an install of APSP6 keeps bombing out and I'm unsure what steps to take next. Software: Version 17.09.04aROM: 17.3(3r)Error in question: Dec 13 21:21:01 Eastern: %INSTALL-3-OPER...
Grabación del webinar Community Live Video con nuestros expertos Edgar Arenas y Martín Arias.Con las soluciones de nuestros expertos, usted no sólo mejora el desempeño de su red, también puede automatizar algunas funciones para mejorar la experiencia...
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine: AdvancedCountry CodeUS Multiple CountriesUSStatistics Timer180CAPWAP MTU1485AP Link LatencyEnabledAP PMK Propaga...
Good day to everyone.I have two Cisco ASA running on FPR2130 assembled into a balancing group, for example:vpn-gw1.example.comvpn-gw2.example.comgeneral address vpn.example.com.Firmware version 9.18.3.56Anyconnect 4.10.07062At the moment, all our emp...
I have an ATA192-3PW-K9 V04 and cannot get it to register. I have it flashed to the latest firmware. I created the device as a workspace with it's mac address and DID/extension in Webex. When I factory reset the device, all I'm doing is going to voic...
We are a healthcare facility. For past several months we have had several complaints from users that calls are often full of static. We are running CUCM 12.5(1)SU8 and the phones are primarily 8811 running current firmware. We have replaced phon...
Hello Everyone, I am contacting you all because i don't seem to find the needed information to resolve my issues, even though there are many similar topic as mine with the same error.We have an infrastructure using FTD ASA5506 with switch CISCO WS-C2...
Presentación del webinar Community Live Con la colaboración de Edgar Arenas y Martín Arias. En las redes de hoy en día, diferentes tipos de tráfico recorren por los nodos del proveedor de servicio. Cada tipo necesita un tratamiento diferente según la...
Hi All,I have a couple of C9300 L3 switches that are connecting to an ASA firewall. The NTP and the syslog server for the switches are located behind a firewall.When one of the switches request/send packets the gateway IP is the source address on the...
Fixing cast iron without welding can be effectively accomplished through the use of a metal epoxy. This method involves cleaning the broken pieces thoroughly to remove any dirt, grease or rust. Once clean, apply a high-quality metal epoxy over the br...
