1841 Routing Between Fast Ethernets
I have a probably simple problem with some. But here is what I have a 1841 router with Frame-Relay link to main office and Pix Firewall connected to a internet connection with VPN to main location.
What I am trying to accomplish but failing is have the serial connection the main for all internal traffic and the Pix (6.254) for the internet traffic. But when the serial goes down I want it to route the internal traffic over the VPN connection.
So right now I have the following config in a extra router and a pix hooked the 192.168.6.0 network on FastEthernet0/0 with laptop in that network also. On Fa0/1 I have the Corporate network hooked up for testing purposes then when I get it working I will put the correct information so the serial connection works.
I can ping the corporate through the pix but if I disconnect the pix I can not ping to any 172.16.0.0 address from the fa0/0 to fa0/1.
I am sure I have left something out but reply back if you have any other questions. I will attach current config below.
Building configuration...
Current configuration : 2379 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.6.0 192.168.6.199
ip dhcp excluded-address 192.168.6.231 192.168.6.255
ip dhcp pool 0
network 192.168.6.0 255.255.255.0
domain-name test.com
dns-server 172.16.1.3 204.189.82.12
default-router 192.168.6.1
username admin privilege 15
class-map match-any VOIP
match access-group 105
match access-group 106
policy-map PriorityRoutes
class VOIP
priority percent 75
interface FastEthernet0/0
description InsideNetwork
ip address 192.168.6.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description TestNetwork
ip address 172.16.13.10 255.255.0.0
duplex auto
speed auto
interface Serial0/0/0
description Frame-Relay
bandwidth 512000
ip address 192.168.250.5 255.255.255.0
encapsulation frame-relay
service-module t1 timeslots 1-8
frame-relay class FRTS
frame-relay map ip 192.168.250.1 33 broadcast
frame-relay map ip 192.168.250.2 34 broadcast
frame-relay lmi-type ansi
service-policy output PriorityRoutes
router eigrp 1
network 172.16.0.0
network 192.168.6.0
network 192.168.250.0
auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 192.168.6.254 permanent
ip route 172.16.0.0 255.255.0.0 Serial0/0/0 192.168.250.1 permanent
ip route 172.16.0.0 255.255.0.0 FastEthernet0/1 172.16.0.8 100
ip route 172.16.0.0 255.255.0.0 FastEthernet0/0 192.168.6.254 150
ip http server
map-class frame-relay FRTS
control-plane
line con 0
login local
line aux 0
line vty 0 4
login
end
Anonymous (not verified) Thu, 03/08/2007 - 06:41
The default route to the corporate network is pointing through the PIX connection becuase of that when pix is removed it is not able to to connect to the corporate netwrok
