L2 MPLS VPN interworking
Mar 2nd, 2007
According to Cisco document. I'm wondering why Cisco GSR series couldn't support ATM VP and port mode interworking. Is it a limitation of the technology/standard itself or simply the s/w or h/w issue of GSR router ?
http://www.cisco.com/en/US/customer/products/sw/iosswrel/ps1829/products_feature_guide09186a00801b2407.html
Overall Rating: 5 (2 ratings)
Rahul Kachalia Thu, 05/24/2007 - 08:51
I assume you are referring to following statement:
"Cisco 12000 series Engine 5 line cards do not support L2VPN interworking on ATM. On other line cards and platforms, only ATM AAL5 VC mode is supported; ATM VP and port mode are not supported."
L2VPN supports 2 types of Interworking, Ethernet and IP. If there is an ATM link type between PE and CE, only bridged or routed AAL5 is supported for all the platforms.
In ATMoMPLS VP traffic is transported over pw when matching VPI in an ATM header is seen from CE regardless of VCI values (excluding reserved VCI's) Similarly in ATMoMPLS Port mode ATM traffic is transported over pw regardless VPI and VCI value set by CE.
Neither in ATMoMPLS VP or Port Mode PE peeks into beyond ATM header so it has no knowledge of upper layer, hence no Ethernet or IP Interworking is not possible. It remains true in Local Switching Interworking scenarios too...
thanks,
rahul.
senthil1976 Tue, 06/05/2007 - 07:18
I think, it is the limitation of ATM line cards in GSR. Ip interworking is possible with ATM to transport over MPLS.
Sen...
Rahul Kachalia Tue, 06/05/2007 - 12:43
Sen,
Yes, Ethernet and IP Interworking in ATM is supported on GSR Linecards but only when ATM VC is configured AAL5 mode. It is not supported in VP or Port Mode, which I believe the original question is...
thanks,
rahul.
atif-siddiqui Wed, 06/13/2007 - 16:09
I am trying to configure local ethernet switching, it is not working, is it supported, not enough documentation is avaliable on the cisco website.
connect cust GigabitEthernet1/1/0.3600 GigabitEthernet1/1/2.3700
Router1 is a GSR, E5 Card.
router1#sh connection
ID Name Segment 1 Segment 2 State Description
1 cut Gi1/1/0.3600 Gi1/1/2.3700 UP
the other side routers cannot ping across.
router1#sh run interface gig
router1#sh run interface gigabitEthernet 1/1/2.3700
Building configuration...
Current configuration : 95 bytes
interface GigabitEthernet1/1/2.3700
encapsulation dot1Q 3700
no ip directed-broadcast
end
interface GigabitEthernet1/1/0.3600
encapsulation dot1Q 3610
end
What else is required. Other routers connected have IP addresses on each side.
Ce1 and Ce2 are 7606.
CE1#sh run interface gigabitEthernet 6/2.3600
interface GigabitEthernet6/2.3600
ip address 10.1.1.2 255.255.255.252
end
CE2:
interface GigabitEthernet6/2.3700
ip address 10.1.1.1 255.255.255.252
end
Here is some infomration:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a00801ea88d.html#wp1132065
Harold Ritter Wed, 06/13/2007 - 18:19
Atif,
L2 Local Switching is supported on the Engine 5 starting with 12.0(32)S.
What level of code do you use?
Hope this helps,
atif-siddiqui Wed, 06/13/2007 - 18:36
Hi Harold,
Is it supported on 7606? running 12.0(33)SRB
and GSR have E5 cards gige, with 12.0(32)SY.
I just don't know what I m missing. It would not ping across.
appereciate your help here.
Atif
swaroop.potdar Wed, 06/13/2007 - 20:33
7600: Only Vlan based local Layer 2 switching is supported with the restriction that you configure the Eompls on an SVI, for which you will need an Enhanced FlexWan or OSM interface facing the core. (This support is there in 12.2SX and SR)
12000: As Harold pointed it is supported from 12.0 (32)S. With Engine 5 interfaces facing the customer.
You configuration looks clean, although one thought, have you tried the VLAN same-port switching as well.
Is the result same for that too.
HTH-Cheers,
Swaroop
atif-siddiqui Thu, 06/14/2007 - 06:01
Hi Swaroop,
so what is meant by EoMPLS on an SVI, beacuse this is a local switching. can you clarify more. Here is a diagram for this setup:
CE----PE------CE, we want to switch locally so that CE can ping other CE.
7606 CE's are using this card:
Ce1#sh module 6
Mod Ports Card Type Model Serial No.
6 9 Supervisor Engine 32 8GE (Hot) WS-SUP32-GE-3B SAL1110JPYB
Mod MAC addresses Hw Fw Sw Status
6 0019.aa5a.3b06 to 0019.aa5a.3b11 4.5 12.2(18r)SX2 12.2(33)SRB Ok
Mod Sub-Module Model Serial Hw Status
6 Policy Feature Card 3 WS-F6K-PFC3B SAL1109JGHM 2.3 Ok
6 Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A SAL1107H4PN 4.0 Ok
Mod Online Diag Status
6 Pass
PE using this card:
L3 Engine: 5 - ISE 10 Gbps
Harold Ritter Thu, 06/14/2007 - 06:06
In the scenario you are testing, the 7600 do not need to support L2 Local Switching at all as they just act as CEs. The GSR does everything.
atif-siddiqui Thu, 06/14/2007 - 06:22
ok agreed. previously I used the 7600 as a local switching point, and it did not work either. So was wondering the HW I have on 7600 will support or not.
tx
Atif
atif-siddiqui Thu, 06/14/2007 - 06:39
here is another setup: where 7606 is switching ethernet locally.
CE(3550)f0/12 <-----> gig1/36 (PE2)7606 6/2.3600 <----> 1/1/0.3600(GW) GSR
CE2#sh ver
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
CE2#sh run interface fastEthernet 0/12
Current configuration : 104 bytes
interface FastEthernet0/12
no switchport
ip address 192.168.200.2 255.255.255.252
duplex full
end
PE:
PE2#sh ver
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRB, RELEASE SOFTWARE (fc6)
cisco CISCO7606 (R7000) processor (revision 1.0) with 458752K/65536K bytes of memory.
Processor board ID FOX11040T3D
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
1 SIP-400 controller (2 GigabitEthernet).
5 Virtual Ethernet interfaces
76 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
PE2#sh connection
9 eth_vlan_sw Gi1/36 Gi6/2.3600 UP
PE2#sh run interface gigabitEthernet 1/36
Current configuration : 76 bytes
interface GigabitEthernet1/36
no ip address
speed 100
duplex full
end
PE2#sh run interface gigabitEthernet 6/2.3600
Current configuration : 67 bytes
end
GW:
GW#sh run int GigabitEthernet1/1/0.3600
Current configuration : 146 bytes
ip address 192.168.200.1 255.255.255.252
end
GW#ping 192.168.200.2
Sending 5, 100-byte ICMP Echos to 192.168.200.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
atif-siddiqui Thu, 06/14/2007 - 07:35
If I use Feature Navigator to look for:
Layer 2 Local Switching: Ethernet to VLAN feature.
These platforms shows up:
3845
7200
IAD2801
IOS:
12.4XJ
12.4T
is this output from feature navigator valid? on the other side documentation do mention 7606 and GSR.
Comments?
Harold Ritter Thu, 06/14/2007 - 12:56
Atif,
L2 Local switching is not supported natively on the PFC3b and requires extra hardware such as the SIP-400 or the ES20.
Hope this helps,
atif-siddiqui Thu, 06/14/2007 - 17:54
Yes. this explains alot.
ok what about GSR, I know that only E5 cards will support, and we have that still did not work.
Thanks a million !
atif-siddiqui Thu, 06/14/2007 - 18:16
can you suggest any other options that we can use, instead of local ethernet switching.
Tx
atif-siddiqui Sun, 06/24/2007 - 20:06
Yes I tried with SIP-400's on 7606 and it works good.
Thanks for your help here.
Atif.
atif-siddiqui Thu, 06/14/2007 - 05:54
Here it is:
I changed both interfaces to same VLAN. Still not able to ping.
end
router1#sh run interface gig 1/1/0.3600
end
VLAN trunk interfaces for VLAN ID 3700:
GigabitEthernet1/1/0.3600 (3700)
Total 39 packets, 1424 bytes input
Total 16 packets, 2914 bytes output
GigabitEthernet1/1/2.3700 (3700)
Total 240 packets, 16166 bytes input
Total 817 packets, 291688 bytes output
CE1:
sh run interface gi6/2.3600
end
Ce2:
end
Ce1 --ping -- ce2:
Ce1#ping 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
PE2#
Rahul Kachalia Thu, 06/21/2007 - 12:55
Will you be able to collect following logs, after clearing counters and then sending 50 ping pkts
- exec slot s controller event clear
- s int g1/1/0
- s int g1/1/2
- s connect
I assume you are running 12.0(32)SY code on GSR...
thanks,
rahul.
atif-siddiqui Sun, 06/24/2007 - 20:08
I will soon post the results here.
I am running 12.0(32)SY3 code on the GSR with E5 Gige cards.
It worked on 7606 with SIP-400 as Harold suggested.
Atif.
atif-siddiqui Mon, 06/25/2007 - 12:39
Configuration:
PE2 <--> GW <--> PE3
description Local Ethernet Switch Test
ip address 172.16.10.1 255.255.255.252
GW#sh ru interface Gi1/1/0.3600
description **Local eth switch test** connect to PE2 g6/2.3600
GW#sh ru interface Gi1/1/2.3700
description **Local eth switch test** connect to PE3 g6/2
encapsulation dot1Q 3750
PE3#sh run interface gigabitEthernet 6/2.3700
description description Local Ethernet Switch Test ** conn. to P4 g1/1/2.3700
ip address 176.16.10.2 255.255.255.252
atif-siddiqui Mon, 06/25/2007 - 12:40
RESULTS:
PE2#ping
Protocol [ip]:
Target IP address: 172.16.10.2
Repeat count [5]: 50
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 50, 100-byte ICMP Echos to 172.16.10.2, timeout is 2 seconds:
Success rate is 0 percent (0/50)
PE2#
GW: (P GSR )
GW#exec slot 1 s controller event
========= Line Card (Slot 1) =========
Switching Stats
Packets punt to RP: 42
HW engine punt: 2
HW engine reject: 40
RX HW Engine Reject Counters
Unrecognized Protocol ID: 32
IP TTL Expired: 8
GW#
GW#sh in
GW#sh int
GW#sh interfaces gi
GW#sh interfaces gigabitEthernet 1/1/0
GigabitEthernet1/1/0 is up, line protocol is up
Hardware is GigabitEthernet, address is 001a.e390.b076 (bia 001a.e390.b076)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, rely 255/255, load 1/255
Keepalive set (10 sec)
Full Duplex, 1000Mbps, link type is force-up, media type is LX
output flow-control is on, input flow-control is on
Last input 00:00:09, output 00:00:09, output hang never
Last clearing of "show interface" counters 00:03:46
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
Available Bandwidth 1000000 kilobits/sec
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
68 packets input, 12364 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 16 multicast, 0 pause input
14 packets output, 4636 bytes, 0 underruns
Transmitted 0 broadcasts
0 lost carrier, 0 no carrier, 0 pause output
GW#s
% Type "show ?" for a list of subcommands
GW#
GW#
GW#
GW#sh int
GW#sh interfaces gi
GW#sh interfaces gigabitEthernet 1/1/2
GigabitEthernet1/1/2 is up, line protocol is up
Hardware is GigabitEthernet, address is 001a.e390.b078 (bia 001a.e390.b078)
Full Duplex, 1000Mbps, link type is force-up, media type is SX
Last input 00:00:01, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:03:57
8 packets input, 3056 bytes, 0 no buffer
0 watchdog, 8 multicast, 0 pause input
59 packets output, 10040 bytes, 0 underruns
GW#
GW#
GW#sho con
GW#sho connect
5 eth_sw Gi1/1/0.3600 Gi1/1/2.3700 UP
Rahul Kachalia Mon, 06/25/2007 - 14:08
Stats are bit confusing. On GSR I see pkts coming in from G1/1/0 and going out G1/1/2 intf, now was that an ICMP pkts I m not sure because traffic was also dropped by LC.
There are couple of things you can try to identify the problem:
Step1:
- Bypass GSR, connect PE2 and PE3 back to back with same VLAN id and ping each other and that should work. If not then resolve the problem.
Step2:
- Turn on "debug ip icmp" on both PE routers. Hookup GSR between PE2 and PE3, ping again and see if it works. Ping from each side of PE and see one-way traffic works. If it still fails try step3.
Step3:
Change VLAN ID to anything below 1000 ID on all 3 boxes. (keep the icmp debugs on)
And if it still fails clear the intf counters and recollect stats from intf and LC. This time if you can also collect following show cmd would be bit helpful
s control tof wahoo phb 0 0 0
Ethernet Local switching is supported on GSR/E5 LC, definitely some basic stuff is broken...
thanks,
rahul.
