can I upgrade 2511
Mar 2nd, 2007
Hi;
I just got 2511 router/ access server..I have lot off questions about this one.
1- can I upgrade the memory and what type of ram( is it the same as the one in the pc?
2- can I upgrade the ios and where to got it from
3- can I use the 2511 as just router only
that is it for now .. the present ISO is 11.something.
ccna here I come :-)
Overall Rating: 5 (1 ratings)
ahmednaas Fri, 03/02/2007 - 09:59
1- yes you can and no it is not.
2- you can upgrade the ios and you get it from cisco.com of course. You need a support account to be able to download ios.
3. yes you can.
good luck :-)
cisco steps Fri, 03/02/2007 - 10:44
Ahmed,
Thanks for the reply. now what kind of ram to do I need and is it realy needed for ccna perparation , same question regarding ios do I realy needs to upgrade . this is just for my ccna for now.
ahmednaas Fri, 03/02/2007 - 10:51
The 2500 ram looks like the old dimms used for 386/486 pc's but those will not work. You need to buy it from cisco's used equipment dealers or ebay.
You should upgrade to 12.x software.
