RTP
Mar 2nd, 2007
Hello I was wondering anyone could tell me which UDP port numbers are used for Source and Dest in the RTP stack?
Thank you
Josh
Overall Rating: 4 (1 ratings)
Brandon Buffin Fri, 03/02/2007 - 13:41
Josh,
RTP uses random ports in the range 16384-32767.
Hope this helps. If so, please rate the post.
Brandon
pkentsmith Fri, 04/20/2007 - 03:08
Josh,
Just to follow on from Brandon. RTP uses the even numbered ports and RTCP uses the odd number ports
PKS
