ASA SSL VPN Client
Mar 2nd, 2007
I have just installed an ASA 5520 and am trying to implement SSL VPN. I have configured the appliance according to Cisco's documentation. I am able to get the SSL SVC VPN connection to connect but once connected I am not able to connect to any devices on my local network. Any help would be appreciated. Thanks Gene
ggilbert Fri, 03/02/2007 - 13:01
Gene - Here are something you want to look into.
What is the IP pool you are assigning the SVC clients to?
What is the internal network you are trying to access to?
For Eg:
Lets say your internal network is 10.10.10.x/24
and the IP address pool you are assigning is 192.168.10.x/24 for the SVC clients,
you would need a NAT exemption ACL.
Do "sh run nat" on the ASA, see if there is any statement like
nat (inside) 0 access-list
If not, using my example, create an access-list like this...
access-list 100 per ip 10.10.10.0 255.255.255.0 192.168.10.0 255.255.255.0
nat (inside) 0 access-l 100
After that, use the SVC client and see if it works.
Rate this post, if it helps!!
Cheers
Gilbert
gbarden Sat, 03/03/2007 - 17:42
I had already done this but it still doesn't work. Thanks for the info though.
gbarden Mon, 03/05/2007 - 12:21
I have done this as well. I am able to see the network with just using webvpn but when I use the SSL client I cannot access the internal network. I need to be able access some servers using RDP.
ggilbert Mon, 03/05/2007 - 13:54
Gene,
Can you please provide the group-policy the SSL clients are using...
sh run all group-policy
Gilbert
