help
Mar 2nd, 2007
I am hoping someone might beable to help me out here. I bought a couple of used 2500 routers to use in hopes of learning some about them. The problem is I do not have their IP addresses, how do I get into the setup files and such. As always all and any help is greatly appreciated in this.
CSCO10892433 Fri, 03/02/2007 - 20:13
Hi, m.j.
On the rear side of 2500 router, there is a port marked as "console", find a roll-over console cable to connect the console port to the com port of your PC.
Open the hypertermial and set the following parameters:
buad rate:9600
databits:8
parity:none
stop bit:1
flow control: none
Then you should be able to configure the router.
I'm looking for some webpages for your reference. I will post them later.
[edit]:Ok, only find this page for catalyst switches, but I think they are almost the same.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008010ff7a.shtml
SSLIN
m.j.shepard Sat, 03/03/2007 - 04:09
thanks that got me into the thing..now I can start playing with it and hopefully NOT be so darned dumb about them...
