Unable to complete IP Communicator Tuning Wizard
Mar 2nd, 2007
When the IP Communicator starts, it runs the Tuning Wizard which fails with the following message:
"Audio Tuning Wizard cannot configure 'Default Windows Audio Device' to record sound."
The IP Communicator does function, but there is a very bad echo on the originating caller's side. The PC in question is using the audio device on the mother board - RealTek High Definition Audio. The audio drivers are up-to-date.
Does anyone have a suggestion on how to resolve this issue?
Thanks!
Overall Rating: 3 (1 ratings)
Ginger Dillon Fri, 03/02/2007 - 13:52
Hi -
There is a bug open for this, we encountered similar problem - http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsb02511&cco_product=Cisco+IP+Communicator&fset=&swver=&keyw=high%20definition&target=&train=
P.S. I attached the document we sent to TAC on this so you can compare if it matches your problem or not. I would also check with TAC on the bugid and see if they have a patch. The timeframe was September/October 2006.
Ginger
fpizzuta Mon, 03/05/2007 - 06:02
Yes, that is the same issue. Thanks for the info - I'll follow up on the bug to see if a patch has been released (not likely).
