How to do this
Mar 2nd, 2007
I want VPn Users to autheticate vs my Microsoft Active Directory LDAP Server.
its not working when I try testing the authentication under ASDM.
I want to allow only people in a specific group or OU access to VPN.
Can someone walk me through the proper configuration?
Domain is xxx.local
OU=Security Groups (under domain)
Group under this OU is ITVPN
Users are in this group
Base DN: ou=Security Groups,dc=xxx,dc=local
Scope= All levels beneath the Base DN
nameing Attribute: uid
Login DN: cn=Administrator,cn=Users,dc=xxx,dc=local
Login Password: xxxxxx
LDAP Attribute Map: ITVPN_GROUP
ITVPN_GROUP is Customer name: ITVPN and Attribute map Name: cVPN3000-IETF-Radius-Class
Gives me an erro that attribute not found.
tim.weid Fri, 03/02/2007 - 15:21
What type of VPN?
Is this going to a concentrator, ASA, is it IPSEC VPN Client or SSL?
zaballa805 Mon, 03/12/2007 - 07:24
i was configuring this same scenario and got the same message. - "Attribute not found"
check your AD attribute and see if you are using the correct attribute value.
What we did was to check on the AD with a LDAP browser.Our naming attribute is cn. we found out that the cn= but when we are connecting via IPSec VPN client, we were just using just the first name as our user id.
hope this helps.
