how to give priority to voice and data
Mar 2nd, 2007
hai,
i have a dout regarding the access list.i created the access list for the given ip listed below
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 125 deny tcp any host 125.17.136.225 eq www
access-list 125 deny tcp any host 125.17.136.226 eq www
access-list 125 deny tcp any host 125.17.136.227 eq www
access-list 125 deny tcp any host 125.17.136.228 eq www
access-list 125 deny tcp any host 125.17.136.229 eq www
access-list 125 deny tcp any host 125.17.136.230 eq www
access-list 125 deny tcp any host 125.17.136.231 eq www
access-list 125 deny tcp any host 125.17.136.232 eq www
access-list 125 deny tcp any host 125.17.136.233 eq www
access-list 125 deny tcp any host 125.17.136.234 eq www
access-list 125 deny tcp any host 125.17.136.235 eq www
access-list 125 deny tcp any host 125.17.136.236 eq www
access-list 125 deny tcp any host 125.17.136.237 eq www
access-list 125 deny tcp any host 125.17.136.238 eq www
i am also having one more ip pool.my requirement is to give priority to my voice packets then data for that what is the configuration i have to do in my router .. either policy map or one more access-list.please help me to solve the issue
Overall Rating: 5 (1 ratings)
Chris Deren Fri, 03/02/2007 - 20:28
You want to use MQC to create classes defining your voice and data traffic, and utilizing policy-map to allocate bandwidth to these classes. Basically you want to create Low Letency Queueing (LLQ) on your egress router. Follow the QoS SRND for all the details you require:
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
HTH,
Chris
CSCO10758684 Sat, 03/03/2007 - 09:48
hai Chris,
Thanks a lot for your help....that was the one which i was looking for
