IPsec passthru on a 2821
Mar 2nd, 2007
I have a 2821 connected to Roadrunner, on the private lan we are using checkpoint vpn client & Watchguard vpn client to connect to the outside wan at our other corporate server. This is where I am missing it. What would need to be configured to allow this passthru?
I tried UDP 500 and 4500, did not seem to work.
Any ideas on how to allow this, as I am fairly new to this.
daviddtran Fri, 03/02/2007 - 20:28
I don't know much about watchguard vpn client
I've worked with Checkpoint firewalls everyday
so I can say that your router configuration is
fine. I need the following information from
you:
1) what version of checkpoint SecureRemote/
SecureClient? NG Feature Pack 3, NG with AI
R55, R55w? NGx R60/R61/R62?
2) Make sure that the checkpoint firewall
is setup for NAT-Traversal (aka, port 2746
for NG with AI R55w or older or 4500 or NGx)
On the Checkpoint SecureRemote/Client, there
is a "Advanced", select the Advanced IKE
Setting and check the box "IKE over UDP
Encapsulation". Kill SecureRemote and
restart it again on your windows box and you
will be able to connnect to the CP with
SecureRemote/Client from behind The 2821
router.
David
CCIE Security
CCSE/CCSA NGx
starlog01 Sat, 03/03/2007 - 20:46
David,
Thanks for the info, I do not have control of the Checkpoint equipment, sorry for the mis-lead. Although - I did get the 2821 to work just fine with Cisco and Watchguard clients. Monday I will get the visiting clients to try again and see if it works with Checkpoint. I opened up one more UDP port 768 for checkpoint from some of the reading. Will keep you posted. Thanks again
daviddtran Sat, 03/03/2007 - 20:56
np. put your email in here so that I can shoot
you an email on monday to see if you have it
square away. I am not a Checkpoint expert but
I've been doing it almost everyday for the past
five years so I've seen a lot of crazy setup.
I am doing a lot of Checkpoint NGx testing
these days but I can take a break to help you
out on monday.
Good luck
David
