Cisco IOS to Catalyst OS configuration converter
Mar 3rd, 2007
hi,
i know Catalyst OS to Cisco IOS configuration converter is there, but i am looking for Cisco IOS to Catalyst OS configuration converter? can any help me in this regard.
looking for a equal command for the following
aaa new-model
aaa authentication login default group tacacs+ enable local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
tacacs-server host 10.203.1.92 key checkingtheswitch.
since it is a Cisco 6509 production switch, i don't want to take chance, as there is a possibility that i might not login if the configuration is incorrect.because i faced similar situation when i implemented in Cisco IOS in the initial stage in one of the edge switch.later i have reset the switch & finally could implement with the working config as mentioned above.
