Static or nat from outside to inside -- Not working
Mar 3rd, 2007
I am trying to set up static translation from out side to inside. I couldn't get across. Debug shows incrementing untranslate_hits . Seen few discussion for this topic but no resolution any where. THanks for your help. Attaching config for reference.
interface Ethernet0/0
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.201.8.10 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
nameif outside
security-level 100
ip address 10.201.66.12 255.255.255.0
access-list outside_access_in extended permit tcp any host 10.201.66.20 eq telnet log
static (inside,outside) 10.201.66.20 10.201.8.2 netmask 255.255.255.255
access-group outside_access_in in interface outside
telnet 10.201.8.0 255.255.255.0 inside
Packet tracer output
packet-tracer input outside tcp 10.201.66.1 1025 10.201.66.20 telnet
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
match ip inside host 10.201.8.2 outside any
static translation to 10.201.66.20
translate_hits = 0, untranslate_hits = 7
NAT divert to egress interface inside
Untranslate 10.201.66.20/0 to 10.201.8.2/0 using netmask 255.255.255.255
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Overall Rating: 5 (1 ratings)
kaachary Sun, 03/04/2007 - 05:12
Your Outside and Inside Interfaces are on same security level.
If you do not have "same-security-traffic permit inter-interface" , this will not work.
*Please rate if helped.
-Kanishka
