vpn between vpn concentrator and router
Mar 3rd, 2007
hi,
one end i am using a vpn concentrator 3000 followed by a router and then isp.on the other end i want to establish vpn connection to this network using a router. how should i configure the router and concentrator?
kindly help as soon as possible ...
Overall Rating: 5 (1 ratings)
deepa_network Sun, 03/04/2007 - 19:59
thank you for your help.
But i have got a router in front of the concentrator .how do i do it?
kaachary Mon, 03/05/2007 - 02:47
The configuration on the Router and concentrator would still remain the same.
If you have a router in front of the concentrator, that means you shud have a NAT (static) entry defined for concetrator Public Intf ip address.
The remote router will use that Public ip address of the conctrato create the tunnel. Also, on the local Router, please make sure you have following ports opened :
UDP 500
UDP 4500
ESP
Hope this answers your questions.
*Please rate if helped.
-Kanishka
