OSPF Problem
Mar 4th, 2007
Hi All ,
My ospf router is showing that it is in INIT state & not forming FULL state , how should i fix the problem.
Overall Rating: 4 (2 ratings)
o_dogorshom Mon, 03/05/2007 - 01:55
for ospf to form adjacency you have to be sure of these parameters:
hello timers
hold timers
MTU size
area
authentication (if configured)
these parameters should be same in both routers to form adjacency.
nileshKahale Sat, 07/21/2007 - 04:15
Hi ,
Is there any command for checking the parameters configured in OSPF.
mohammedmahmoud Sat, 07/21/2007 - 05:08
Try:
sh ip ospf neighbor
Then use the interface to do:
sh ip ospf interface
P.S The document provided by Danilo is very useful.
HTH,
Mohammed Mahmoud.
bellocarico Tue, 07/24/2007 - 01:28
Please remember that also the "stub" flag must match between interfaces in the same area.
