ssh on pix using puty client
Mar 4th, 2007
i cant access my pix using ssh. i have configured the following. There is no access-list on the inside interface
INSIDE IP - 192.168.1.1/24
domain-name xxx.com
hostname Company
ca generate rsa key 2048
ca save all
ssh 192.168.1.0 255.255.255.0 inside
telnet and ping are ok.
thanks a lot.
kaachary Sun, 03/04/2007 - 05:22
Try this :
ca zeroize rsa
ca gen rsa key 1024
ca save all
If you are using putty as SSH client, make sure, the SSH version 1 and 2 both are selected.
*Please rate if helped.
-Kanishka
scottmac Sun, 03/04/2007 - 11:11
Which version of PIX OS are you using?
Some of the older versions do not support SSH, others (up to 6.35 I think) only support SSH version 1.
Good Luck
Scott
kaachary Mon, 03/05/2007 - 00:56
Are you able to telnet to port 22 from Command line ?
Does it open up a blank window ?
If yes, then ther's someting wrong with the SSH client you are using. Make sure putty is setup correctly. Also, did you verify that SSH 1 and 2 both are selected on it.
-Kanishka
peteruwa Thu, 05/17/2007 - 00:49
You have mised out
"aaa authentication ssh console LOCAL" in your configuration. Add it and try connecting again.
pet
