DSL VPN
Answered Question
Mar 4th, 2007
Dears;
I have 2811 router connected to the internet using ADSL connection;
i successfully configured the router to access the internet.
the image which router gas is c2800nm-ipbasek9-mz.124-4.
I need to configure the router to establish VPN tunnel.
which image should i installed .
Correct Answer by Danilo Dy about 9 years 7 months ago
Your HWIC-1ADSL is in the show diagnostics. According to this link it first support in 12.4(4)T http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd80394b7e.html
Use ADVANCED SECURITY 12.4(11)T with the filename c2800nm-advsecurityk9-mz.124-11.T1.bin (ED) instead
Overall Rating: 5 (1 ratings)
Danilo Dy Sun, 03/04/2007 - 04:47
You mean IPSEC VPN?
Here are the IOS that supports IPSEC VPN for 2811, all of them requires 256MB DRAM and 64MB FLASH
Advance IP Services c2800nm-advipservicesk9-mz.124-13.bin
Advance Enterprise Services c2800nm-adventerprisek9-mz.124-13.bin
Advance Security c2800nm-advsecurityk9-mz.124-13.bin
ahmednaas Sun, 03/04/2007 - 07:52
I think the image you have now supports IPSEC VPN. The K9 in the image name indicates that it supports IPSEC/3DES. Did you try configuring a VPN on it?
w_basheer Sun, 03/04/2007 - 12:51
Dear;
i installed the image :
But i can't configure the ATM interface in my router?
i can't find the interface ATM command.
can you help me please.
ahmednaas Sun, 03/04/2007 - 13:13
when you do a "sh ver", can you see the interface listed?
Can you post your config?
w_basheer Sun, 03/04/2007 - 14:08
Dear Sir;
previously i had the image:c2800nm-ipbasek9-mz.124-4.T.bin.
and successfully configured the ATM and dialer interface and connected to the internet.
but now i have to configured VPN Connection.
so i need to upgrade the image to security image so i can applied the commands.
but when i upgrade the image to c2800nm-advsecurityk9-mz.124-13.bin.
i can't find the ATM interface configuration.
I will send to you my run configurations.
ahmednaas Sun, 03/04/2007 - 14:32
Please check the following first:
-show version
Your ATM interface should be listed among the found interfaces.
-show interface
Your atm interface should be listed along with the ethernet interfaces.
If the ATM interface does not show up in either situation, you should check to the see if the card is correctly seated.
If it shows up in both commands, then you should be able to configure it.
Danilo Dy Sun, 03/04/2007 - 21:39
Can you post the "show version" and "show diagnostic" output here?
w_basheer Sun, 03/04/2007 - 22:23
ITS-BAH-OFFICE#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(13), )
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 22-Feb-07 15:39 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
ITS-BAH-OFFICE uptime is 9 hours, 40 minutes
System returned to ROM by reload at 20:57:15 UTC Sun Mar 4 2007
System image file is "flash:c2800nm-advsecurityk9-mz.124-13.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX0925A5RP
2 FastEthernet interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Danilo Dy Sun, 03/04/2007 - 22:34
Yeeesh, your ATM interface is not in the "show version". an you post the "show diagnostic" as well?
ahmednaas Sun, 03/04/2007 - 22:52
I thought you needed 12.4 T release to support HWIC-1ADSL Card. Your previous software must have been a 12.4(4T) or greater:
WIC Slot 1:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware Revision : 7.0
Top Assy. Part Number : 800-26247-01
Part Number : 73-9932-05
Board Revision : B0
Deviation Number : 0
Fab Version : 07
PCB Serial Number : FOC102207TV
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : HWIC-1ADSL
Version Identifier : V01
CLEI Code : COUIADECAA
EEPROM format version 4
ahmednaas Sun, 03/04/2007 - 23:04
Please note the in your first post you did not mention the T. You had "c2800nm-ipbasek9-mz.124-4". I just went through the thread again and noticed that in a later post you added the T: "c2800nm-ipbasek9-mz.124-4T".
You need a T train release to support your HWIC-1ADSL card.
w_basheer Sun, 03/04/2007 - 21:45
THIS CONFIGURATION for advsecurityk9
Building configuration...
Current configuration : 5089 bytes
version 12.4
service password-encryption
hostname ITS-BAH-OFFICE
boot-start-marker
boot system flash c2800nm-advsecurityk9-mz.124-13.bin
boot-end-marker
enable secret 5 $1$1elu$VxanwUgYjKXI3DC7V8L4G.
aaa new-model
aaa authentication login default group tacacs+ local
aaa session-id common
ip cef
ip dhcp excluded-address 10.0.0.138
ip dhcp excluded-address 10.0.0.90
ip dhcp excluded-address 10.0.0.213
ip dhcp excluded-address 10.0.0.200
ip dhcp excluded-address 10.0.0.50
ip dhcp excluded-address 10.0.0.52
ip dhcp excluded-address 10.0.0.100
ip dhcp excluded-address 10.0.0.111
ip dhcp excluded-address 10.0.0.145
ip dhcp excluded-address 10.0.0.220
ip dhcp excluded-address 10.0.0.244
ip dhcp excluded-address 10.0.0.17 255.255.255.0
ip name-server 217.17.233.101
ip name-server 217.17.233.49
username admin privilege 15 secret 5 $1$JDJY$sEU32UxRvVqmmLZV3JWSX.
interface FastEthernet0/0
ip address 10.0.0.96 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Dialer0
ip address 89.148.43.29 255.255.255.252
ip nat outside
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname itsbah1
ppp chap password 7 111D0C081013055D56
ppp pap sent-username itsbah1 password 7 03104E06010E2F1D1C
ip route 0.0.0.0 0.0.0.0 89.148.43.1
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http secure-server
ip nat pool pool 89.148.43.29 89.148.43.29 netmask 255.255.255.255
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 10.0.0.209 23 89.148.43.29 23 extendable
ip nat inside source static tcp 10.0.0.209 21 89.148.43.29 211 extendable
ip nat inside source static tcp 10.0.0.213 3389 89.148.43.29 1111 extendable
ip nat inside source static tcp 10.0.0.209 1156 89.148.43.29 1156 extendable
ip nat inside source static tcp 10.0.0.209 1521 89.148.43.29 1521 extendable
ip nat inside source static tcp 10.0.0.220 1720 89.148.43.29 1720 extendable
ip nat inside source static tcp 10.0.0.220 1907 89.148.43.29 1907 extendable
ip nat inside source static tcp 10.0.0.244 3001 89.148.43.29 3001 extendable
ip nat inside source static tcp 10.0.0.90 3389 89.148.43.29 5555 extendable
ip nat inside source static tcp 10.0.0.209 7710 89.148.43.29 7710 extendable
ip nat inside source static tcp 10.0.0.209 7720 89.148.43.29 7720 extendable
ip nat inside source static tcp 10.0.0.209 7730 89.148.43.29 7730 extendable
ip nat inside source static tcp 10.0.0.209 7740 89.148.43.29 7740 extendable
ip nat inside source static tcp 10.0.0.209 7777 89.148.43.29 7777 extendable
ip nat inside source static tcp 10.0.0.244 9999 89.148.43.29 9999 extendable
access-list 1 permit 10.0.0.0 0.0.0.255
dialer-list 1 protocol ip permit
end
w_basheer Sun, 03/04/2007 - 21:47
This configuration for c2800nm-ipbasek9-mz.124-4.T.bin
I have ATM Interface
Current configuration : 3405 bytes
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool office-pool
import all
network 10.0.0.0 255.255.255.0
dns-server 217.17.233.49
default-router 10.0.0.138
ip address 10.0.0.138 255.255.255.0
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ip classless
no ip http server
no ip http secure-server
control-plane
end
